tbh i don't think there is a website where you can "build" your loop and check compatibility.
That's why it calls custom watercooling ... it's custom ... meaning you'll have to do research and visit manufacturer websites yourself and check speccs.
Scroll trough forum's and gather a lot of info. that's the only way.
https://linustechtips.com/topic/143816-water-cooling-help/#findComment-1920400
