I've been wanting to build my own PC ever since I've seen people build them themselves on camera, so I'm finally doing it now.
I'm on a budget of about 600 euros and I've already gathered a few parts for the build, having a PSU, case and more than enough storage already.
I made a spreadsheet of the remaining parts I need, and I would like to see if I could optimize this build any further, making it more efficient before I actually buy it and try to build it myself.
https://docs.google.com/spreadsheets/d/1oWIM2WUCM1H84sITLDQFBUG-ahfNvBZbdC7rsHvUz4M/edit?usp=sharing
https://linustechtips.com/topic/1437012-first-build/
Start by listing your parts in pcpartpicker.com it will tell you if they are compatible and only let you pick parts that are. Your list looks OK, but I have never heard f that PSU brand before.
They have a guide to a $700 one, you can use this to start yours https://pcpartpicker.com/guide/TydnTW/entry-level-intel-gaming-build and modified as needed.
https://linustechtips.com/topic/1437012-first-build/#findComment-15437390
I just made my pcpartpicker list and it seems to be compatible, I think. https://pcpartpicker.com/list/4jgtW4
As for the PSU, I don't know if I should replace it or keep it, since I've been using it for quite a while and didn't have any problems with it, but I read that it's actually a really bad PSU (https://i.imgur.com/UOu1Vq6.jpg they put Sharkoon in the worst tier)
I don't know whether to risk it and use it, or buy another PSU.
https://linustechtips.com/topic/1437012-first-build/#findComment-15437437
A basic 600W PSU from a reputable brand like Corsair or EVGA will only set you back another $50. A fully modular 80+ Gold from EVGA can be had for $70 if you're feeling fancy. If I were you, I'd want a power supply I can trust not to fry all the other components I spent so much on.
To save a little money, you can probably get away with using the stock cooler that comes with the CPU. It won't impress the ladies at the club, but it's good enough for a build like this, and IMO that money is better spent on a reliable PSU.
Main rig:
CPU: AMD Ryzen 9 5900X
GPU: Sapphire RX 6800XT
RAM: 2x16GB DDR4
Motherboard: Asus ROG B550-I
Storage: 2TB Samsung 980 PRO NVMe, 4TB WD Blue HDD
PSU: Corsair RM850x
Case: Fractal Torrent Nano
OS: Linux Mint 20.2 Cinnamon
NAS:
CPU: AMD Ryzen 4600G
Motherboard: ASRock Rack X470D4U
RAM: 2x16GB DDR4
Storage:
  • Boot: 16GB Supermicro SATADOM
  • Pool 1: 2x6TB WD Red Plus HDD mirrored, for bulk storage
  • Pool 2: 2x500GB NVMe SSD mirrored, for apps like Plex and Adguard Home
PSU: Be Quiet SFX-L 600W
Case: Silverstone CS351
OS: TrueNAS SCALE
https://linustechtips.com/topic/1437012-first-build/#findComment-15437674
