I recently upgraded my gpu but I'm not getting no significant performance boost my fps are quite low with the specs i have gpu also doesn't get utilized how to fix this :')
Specs-  B550 AORUS ELITE AX V2
            AMD Ryzen 7 3700X 8-Core Processor
            NVIDIA GeForce RTX 3070 FE
            ADATA Ram 8x2 3200mhz DUAL CHANNEL
            PSU DEEPCOOL 850WATTS
I have attached some screenshot of ingame benchmark in cyberpunk 2077 (running in 1080p issue with most of the games )
https://linustechtips.com/topic/1436851-low-gpu-usage-terrible-framerates/
Try another game. Cyberpunk is one huge mess of a game.
GAMER
SPEC: HYTE Y60 White/Black + Custom ColdZero ventilation sidepanel – AMD Ryzen 7 9800X3D + ASUS ROG RYUJIN III 360 – G.SKILL Trident Z5 Neo RGB DDR5-6000 64GB CL30-40-40-96 – ASUS RTX ROG ASTRAL 5080 OC – ASUS ROG STRIX B850-E GAMING Wi-Fi – Samsung EVO Plus 1TB, Samsung EVO Plus 1TB – Corsair HX1200i
GEAR: Samsung Odyssey Neo G9 G95NC 57" – ASUS ROG Harpe Ace Aim Lab Edition Wireless – ASUS ROG Claymore II Wireless –
ASUS ROG Sheath BLK LTD – FiiO K7 DAC/AMP + Beyerdynamic DT 770 PRO X (Limited Editon), Edifier S351DB, Steelseries Arctis Nova Pro Wireless
Home LAB
SPEC: Corsair 4000D Airflow TG – AMD Ryzen Threadripper 1950X – Corsair Vengeance LPX 128GB (CMK32GX4M2D3000C16 x4) – ASUS GeForce GT710 1GB – ASUS ROG Zenith Extreme – ROG AREION 10Gbps – Toshiba XG6 1TB, WD 256GB, Kioxia 256GB – Corsair HX750
GEAR: Philips 346B1C 34" – Logitech MX Keys – Logitech M705 – Jabra Evolve2 75
Racing SIM
GEAR: Sim-Lab GT1 EVO Sim Racing Cockpit + Integrated Vario Triple mount – Svive Racing D1 Seat – MSI 325CQRXF 32" x3 – Simagic Alpha Mini + Simagic GT4 (Dual Clutch) – CSL Elite Pedals V2 – Logitech K400 Plus
Just now, killinbro said:
Same issue in other games.
Maybe drivers from old GPU is messing things up. Have you tried DDU?
GAMER
Home LAB
Racing SIM
i have tried ddu fresh os install , tried old drivers everything the temps are also fine when i stress test the gpu i get full utilization and everything is normal but in games not getting what is should get.
XMP/DOCP is confirmed enabled?
GAMER
Home LAB
Racing SIM
If a stress test uses the full GPU, then it might be a CPU bottleneck. I would look at the per-core usage in Task Manager, if the game isn't optimized for multi-core you might have one or two cores maxed out while the others are idle. I'm not clear from your initial post, is the framerate actually worse than before you upgraded the GPU, or is it just not as good as you hoped it would be?
Main rig:
CPU: AMD Ryzen 9 5900X
GPU: Sapphire RX 6800XT
RAM: 2x16GB DDR4
Motherboard: Asus ROG B550-I
Storage: 2TB Samsung 980 PRO NVMe, 4TB WD Blue HDD
PSU: Corsair RM850x
Case: Fractal Torrent Nano
OS: Linux Mint 20.2 Cinnamon
NAS:
CPU: AMD Ryzen 4600G
Motherboard: ASRock Rack X470D4U
RAM: 2x16GB DDR4
Storage:
  • Boot: 16GB Supermicro SATADOM
  • Pool 1: 2x6TB WD Red Plus HDD mirrored, for bulk storage
  • Pool 2: 2x500GB NVMe SSD mirrored, for apps like Plex and Adguard Home
PSU: Be Quiet SFX-L 600W
Case: Silverstone CS351
OS: TrueNAS SCALE
The current screenshot i gave is just for example the issue I'm facing i should get more fps then what im getting and for other games example valorant or rainbow six i had a 1060 before and there no change in fps maybe 20 30 fps increment the issue is in most games some games runs fine for a while then fps just dips temps are also normal  The framerates are not worse then before but the framerate im getting is not what i hoped for according to other benchmarks the difference is to much  .
In the performance overlay, I can see GPU utilization, but not CPU utilization. Can you turn on CPU utilization as well?
Mostly because your CPU is only drawing 40 watts, which is surprising given the situation.
That's what they are designed to do. GPU stress tests do not represent real life performance in games, as they do not use the CPU as much or in the same way. There are no NPC pathfinding calculations to do when the gpu is just making a furry eyeball spin (furmark).
Just now, DANK_AS_gay said:
Do you have anything running in the background? what settings are you running at? Do you have Vsync on?
Nothing running on background vsync is off i tired with on same result and its running on ultra RT with dlls quality  even if i crackdown settings kind of same performance
That's my point, if a stress test which only slams the GPU and nothing else runs and gets typical scores, then it's probably not the GPU's fault. It's probably another component holding back the shiny new GPU in real-world gaming loads that use all the components evenly.
I'd still like to see the CPU usage per core. Could be a couple of them are maxed out, and the rest are idle because the game isn't optimized for multi core. If you're turning down the graphics and still seeing the same low framerate, it might be that the only solution is unfortunately buying a faster CPU.
Main rig:
RAM: 2x16GB DDR4
PSU: Corsair RM850x
NAS:
RAM: 2x16GB DDR4
Storage:
OS: TrueNAS SCALE
