Hey Guys,
I would like to know if it's possible to connect my wireless tv (connected to my wifi) to my desktop (connected with lan to the rooter (which is also the wifi rooter)).
I would like to screen share what I have on my computer to my tv, but wirelessly.
It seems to be possible if the tv and the computer are on the same wifi network, but my desktop has no wifi and is only connectable though lan.
I am a but stuck here, but I'd be happy to know if it is even possible to do in the first place.
Thx in advance!!
https://linustechtips.com/topic/1436724-wireless-tv-question/
With any of these solutions, don't expect identical performance to running a wire. That's what you should do, hands down.
To be quite honest if I want to play something on my TV, I simple stream it with a Chromecast. All the wireless display option are just trash, in most cases.
Ryzen 7 7800x3D -  Asus RTX4090 TUF OC- Asrock X670E Taichi - 32GB DDR5-6000CL30 - SuperFlower 1000W - Fractal Torrent - Assassin IV - 42" LG C2 - Windows 11 Pro
https://linustechtips.com/topic/1436724-wireless-tv-question/#findComment-15435422
