AIO not working properly
Solved by Origami Cactus,
Can't really tell from the pictures of what exact model of AIO you have, but Coolermaster had at least a couple of bad batches of AIOs, so I would just RMA that to get a new fixed one. The noise is def not normal.
If you think it is because of air, you can try mounting your AIO to the top of the case, but right now it should have plenty of room for air, unless your AIO really has dryed up (air is collected to the highest point of the loop)
