Budget (including currency): 500 euro (550 dollars)
Country: Netherlands
Games, programs, or workloads that it will be used for: mostly gaming
Other details: I don't have any existing parts apart from a keyboard, mouse, screen, headphones.
This is my first pc I will be building. I do know a bit of the basics, i just really want some tips and suggestions. I thought the smartest way to go was a good CPU with an APU to have a nice upgrade path.
I'm excited to hear about your comments and suggestions.
https://linustechtips.com/topic/1436046-my-first-ever-pc-build/
Could u send the link?
https://linustechtips.com/topic/1436046-my-first-ever-pc-build/#findComment-15430327
its a little bit over budget but this is what i found for you https://nl.pcpartpicker.com/list/MgzQyK
https://linustechtips.com/topic/1436046-my-first-ever-pc-build/#findComment-15430332
https://nl.pcpartpicker.com/list/nr7fpH this is what ive come up with, the case ive chosen to your motherboard which has good airflow and is that bit cheaper, its also better to have 2 sticks than 1 stick of ram, it is also better to get a motherboard with a heatsink over the vrms/mosfets for a lesser panic attack (trust me i speak from experience). Also youd need a usb wifi dongle or a wireless internet pcie card if youre not going to go wired for internet
https://linustechtips.com/topic/1436046-my-first-ever-pc-build/#findComment-15430375
22 hours ago, mustafa654 said:
But if u need it to be in budget this is for you https://nl.pcpartpicker.com/list/gYL3Rv but i really recommend for you to stretch ur budget and get this https://nl.pcpartpicker.com/list/MgzQyK
the problem is that i am on a very tight budget. i'm 17 and still working in a convenience store, (6 dollars per hour). i really want a pc that will be okay enough for most of the games. with a big upgrade path. i will consider the build you have sent me because it is very interesting. (thnks for the support btw)
https://linustechtips.com/topic/1436046-my-first-ever-pc-build/#findComment-15431900
i sent you two if ur budget is that tight i recommend just get this  https://nl.pcpartpicker.com/list/gYL3Rv but i really do recommend this https://nl.pcpartpicker.com/list/MgzQyK just choose what more confortable for you
https://linustechtips.com/topic/1436046-my-first-ever-pc-build/#findComment-15431981
