New build not turning on. Need help please
Solved by An0maly_76,
30 minutes ago, Bryce9498 said:I got it to power on. There is an error light under the VGA label on the motherboard? Is that video signal?
Means it sees something it doesn't like in the GPU path. Hence the reason I suggested making sure it is seated properly. Also make sure contacts are clean. Even a speck or two of dust can be a problem.
Featured Topics
Flashmatrix ·
Posted in Storage Devices2 -
Nixx23 ·
Posted in Storage Devices0 -
Witchandglad ·
Posted in Phones and Tablets1 -
ElChales ·
Posted in CPUs, Motherboards, and Memory2 -
Steve Chan ·
Posted in LMG Sponsor Discussion2 -
