im planing on a new mATX build up, so far i have come to this:
bitfenix prodigy m - 100€
asus gryphon z87 - 150€
intel i5 4670k - 220€
corsair h80i - 100€
patriot viper3 black mamba 2133mhz 16gb kit - 170€
seasonic ss660xp platinum - 150€
gigabyte gtx 760 oc windforce (budget decision) - 250€
Any suggestions would be appreciated.
ty
https://linustechtips.com/topic/143516-new-build-up-help/
Read this please. Some more info would be nice.
Setup Video -----------Peasant Crushing Specs----------- 4K Benchmarks
-CPU- i7 3930k @4.8GHz 1.4v -Mobo- Asus Rampage IV Extreme -GPUs- 2x GTX Titan Hydrocopper SLI -RAM- 32GB (8x4GB) Corsair Vengeance 1600MHz -Storage- 500GB Samsung 840 SSD | 2TB WD Green HDD
-Monitors- 3x BenQ XL2420T | 1x Dell U2713HM -Mouse- Steelseries Rival -Keyboard- Corsair K70 Cherry MX Brown -Headphones- Audio Techinca ATH-M50 -Microphone- RØDE NT1-A
https://linustechtips.com/topic/143516-new-build-up-help/#findComment-1916026
for a mATX case i would recommend a reference GPU for the blower fans, if there isnt a fan pushing LOTS of air past the GPU and out of the case, doing a check on my computer right now, with panel on and normal it runs very hot, 80 on load, i wanted to check if its the card alone or if its airflow related aswell so i took a table fan and placed it perfectly and now its running at 50-60 under load
Proud Member of the Glorious PC Master Race
https://linustechtips.com/topic/143516-new-build-up-help/#findComment-1916037
Budget? What are you going to use it for? Etc. But if it is just for gaming, it seems like a pretty good build.
Case: Corsair Vengeance C70 Gunmetal Black CPU: i7-4770k Cooler: Corsair H100i RAM: 8gb Corsair Vengeance Pro GPU: ASUS Direct CUII 770 MOBO: Asus Maximus VI Hero PSU: EVGA Supernova 1000 G2
https://linustechtips.com/topic/143516-new-build-up-help/#findComment-1916047
