DO you have a deskpad? If it only happens when you move the mouse fast, I'd say pickup a deskpad. Usually that means your tracking in your mouse is not able to keep up with what you are doing. a solid pad helps a TON! IF there is a DPI setting on your mouse, try adjust that as well.
https://linustechtips.com/topic/1432439-mouse-problem/#findComment-15405099
