i9 9900k problems?
Go to solution Solved by unclewebb,
10 minutes ago, mozartt said:
only shows up to 12 instead of the full 16 processors
Did you clear the box and reboot? If it is on 12 it will not let you select 16. This box should never be checked.
It seems to get checked automatically when you swap processors. Many people have had this same issue.
So I just installed a brand new 9900k in my system from a i7 8700 and in task manager its saying its a 6 core 12 thread CPU. Another thing that is weird is I'm getting a cinebench score of 8600 when the average for a non OC 9900k should be getting around 12,000. I also tested my FPS in games and there is no difference to my old tests, I have researched what stats other people get with systems identical to mine and their stats are much different/better. I'm a little concerned because I just spent a good amount of money on this CPU and new cooler for it, to get nothing out of it.
https://linustechtips.com/topic/1432309-i9-9900k-problems/
What does CPUZ say?
This is how my stock i9 9900k reads.
RIG#1 CPU: AMD, R 7 5800x3D| Motherboard: X570 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 3200 | GPU: EVGA FTW3 ULTRA  RTX 3090 ti | PSU: EVGA 1000 G+ | Case: Lian Li O11 Dynamic | Cooler: EK 360mm AIO | SSD#1: Corsair MP600 1TB | SSD#2: Crucial MX500 2.5" 2TB | Monitor: ASUS ROG Swift PG42UQ
RIG#2 CPU: Intel i9 11900k | Motherboard: Z590 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 3600 | GPU: EVGA FTW3 ULTRA  RTX 3090 ti | PSU: EVGA 1300 G+ | Case: Lian Li O11 Dynamic EVO | Cooler: Noctua NH-D15 | SSD#1: SSD#1: Corsair MP600 1TB | SSD#2: Crucial MX300 2.5" 1TB | Monitor: LG 55" 4k C1 OLED TV
RIG#3 CPU: Intel i9 10900kf | Motherboard: Z490 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 4000 | GPU: MSI Gaming X Trio 3090 | PSU: EVGA 1000 G+ | Case: Lian Li O11 Dynamic | Cooler: EK 360mm AIO | SSD#1: Crucial P1 1TB | SSD#2: Crucial MX500 2.5" 1TB | Monitor: LG 55" 4k B9 OLED TV
RIG#4 CPU: Intel i9 13900k | Motherboard: AORUS Z790 Master | RAM: Corsair Dominator RGB 32GB DDR5 6200 | GPU: Zotac Amp Extreme 4090  | PSU: EVGA 1000 G+ | Case: Streacom BC1.1S | Cooler: EK 360mm AIO | SSD: Corsair MP600 1TB  | SSD#2: Crucial MX500 2.5" 1TB | Monitor: LG 55" 4k B9 OLED TV
https://linustechtips.com/topic/1432309-i9-9900k-problems/#findComment-15404300
  • BIOS is up to date?
  • CPU-Z IDs it as a 9900K?
  • BIOS has all cores/threads set as enabled?
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
https://linustechtips.com/topic/1432309-i9-9900k-problems/#findComment-15404302
48 minutes ago, mozartt said:
CPU-Z reads the same 6 cores 12 threads, Mhz fluctuates a lot sometimes down to 800 maybe I should try to update BIOS? I have never updated it since the board was installed. Also in BIOS it says 8 core 16 thread.
If it is a Z370 the bios may need updating. If it is a Z390 it should not.
https://linustechtips.com/topic/1432309-i9-9900k-problems/#findComment-15404417
3 minutes ago, unclewebb said:
@mozartt
When you change CPUs, open msconfig, select the Boot tab, press the Advanced options... button and clear the Number of processors box and reboot This allows Windows to find all of your cores and threads.
This is one of the first things I tried but it only shows up to 12 instead of the full 16 processors
https://linustechtips.com/topic/1432309-i9-9900k-problems/#findComment-15404447
https://linustechtips.com/topic/1432309-i9-9900k-problems/#findComment-15404453
Thank you sir, this solved the issue ✅
https://linustechtips.com/topic/1432309-i9-9900k-problems/#findComment-15404538
