I’m upgrading CPU but I’ve done some research and it says i need to update my bios and it should work, my mobo doesn’t support flashback so if i install zip extract it then download bios update do i take out the current cpu afterwards then put 5600x in? Please help me.
https://linustechtips.com/topic/1431426-compatibility-issues/#findComment-15398081
You would update the bios with your current cpu. After you have confirmed it has updated (Check in bios) then you would install the 5600X.
The bios version that supports the 5600X is listed as 'Beta' so I personally wouldn't use it yet, as you don't know how stable it is.
https://linustechtips.com/topic/1431426-compatibility-issues/#findComment-15398133
Why not just try it out and get another board if it dosen't work out? @Owrw
Gaming PC:
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: Crucial 2x16gb, 3200  JEDEC. | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Asus Prime RTX 5070ti OC| Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: Kingston Renegade 2TB and Corsair MP510 960gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
Linux PC:
CPU: Ryzen 7700| Motherboard: Asus A620M-CSM | RAM: Crucial Pro 2x48gb, 5600  JEDEC. | PSU: Corsair CX750 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: MSI Gaming X RTX 3090 | Case: Lian Li Dan Cases A3-mATX black |Storage: SN7100 2TB + Samsung 860 EVO 512gb | Cooling: CPU: Thermalright Peerless Assassin Mini Fan(s): Noctua 1x NF-A14x25 Chromax
https://linustechtips.com/topic/1431426-compatibility-issues/#findComment-15398150
I've have updated the bios and I will install the 5600x soon, "Beta" is quite vague and it wouldnt be posted if its going to be that unstable.
https://linustechtips.com/topic/1431426-compatibility-issues/#findComment-15398820
2 hours ago, Owrw said:
What’s the worst that will happen? Display doesn’t pop up? I’ve got a Tomahawk MAX ii in case of the worst…
Hard to say. With it being beta it just means it hasn't been fully tested, so it could be buggy/unstable etc. If you have a Tomahawk I would just use that, as it is a much better board and it has bios flashback as well. The bios for the 5600X is also a full release.
https://linustechtips.com/topic/1431426-compatibility-issues/#findComment-15399516
The tomahawk is from a friend for £45 so I will buy it if my board isn’t capable
https://linustechtips.com/topic/1431426-compatibility-issues/#findComment-15399569
The tomahawk is from a friend for £45 so I will buy it if my board isn’t capable, I already updated the bios and the pc is fine so far, so lets hope it will be fine when I put the cpu in.
https://linustechtips.com/topic/1431426-compatibility-issues/#findComment-15399570
That new or 2nd hand ? I probably wouldn't pay more than £35 if used and little to no warranty. The Tomahawk is currently £70 an Amazon, but I am pretty sure I have seen it, and boards like the B450 Mortar Max closer to £60.
https://linustechtips.com/topic/1431426-compatibility-issues/#findComment-15399671
