Hey guys,
Once again I'm having some problems with my setup.
This time it's my monitor. The Asus VE247 24" 1080p, to be more specific.
The problem is, that the overdrive feature is by default enabled, but it causes some serious ghosting issues.
By bringing up the "secret" blue menu, I'm able to turn overdrive off no problem.
But every time my monitor turns off, when it's idling or when I shut down my computer, the overdrive feature will be enabled again, and I have to disable it again.
Sometimes it will even turn the overdrive feature back on at complete random while the monitor is powered on.
So my question is: Is it possible to turn the OD feature off once and for all, without having to turn it off manually all the time?
Thanks in advance!
CPU: i7-4770k (LM modded) - MB: GA-Z87X-UD3H - RAM: HyperX, 16GB 1866MHz - GPU: Palit GTX 980Ti Super - Storage: 1TB HDD + 500GB/120GB SSD (850 Evo/840) - Monitor: Predator XB271HU - PSU: 700W BeQuiet 80+ Gold
https://linustechtips.com/topic/143039-asus-ve247-overdrive-problem/
