Hey there, since I even originally put my PC together I've noticed constant stutters and performance issues even though I have a pretty decent machine. For example sometimes I can't even run Fortnite on minimum settings without constant frame spiking from 144 all the way to 30 and then back up again. I think I've finally narrowed it down to a cooling issue after realizing that Speccy shows my parts running pretty dang hot, I've had my drive just completely fail and die before and I only now realized it might've been heat damage. So what I'm really asking is how the heck should I reconfigure my fans? Right now I have 4 case fans, two in the front, one in the back, and one on top. Both front and back fans are intake and top fan is exhaust(assuming the logo shows a forward face). They're also all no name fans with no software to adjust speed or anything like that. should I turn around any of them or is another part causing problems?
https://linustechtips.com/topic/1430172-pc-always-running-hot/
Please tell what the exact temps was that Speccy reported, also what case you are using, and take a picture of your PC. It will help greatly.
And your PC specs btw
GAMER
SPEC: HYTE Y60 White/Black + Custom ColdZero ventilation sidepanel – AMD Ryzen 7 9800X3D + ASUS ROG RYUJIN III 360 – G.SKILL Trident Z5 Neo RGB DDR5-6000 64GB CL30-40-40-96 – ASUS RTX ROG ASTRAL 5080 OC – ASUS ROG STRIX B850-E GAMING Wi-Fi – Samsung EVO Plus 1TB, Samsung EVO Plus 1TB – Corsair HX1200i
GEAR: Samsung Odyssey Neo G9 G95NC 57" – ASUS ROG Harpe Ace Aim Lab Edition Wireless – ASUS ROG Claymore II Wireless –
ASUS ROG Sheath BLK LTD – FiiO K7 DAC/AMP + Beyerdynamic DT 770 PRO X (Limited Editon), Edifier S351DB, Steelseries Arctis Nova Pro Wireless
Home LAB
SPEC: Corsair 4000D Airflow TG – AMD Ryzen Threadripper 1950X – Corsair Vengeance LPX 128GB (CMK32GX4M2D3000C16 x4) – ASUS GeForce GT710 1GB – ASUS ROG Zenith Extreme – ROG AREION 10Gbps – Toshiba XG6 1TB, WD 256GB, Kioxia 256GB – Corsair HX750
GEAR: Philips 346B1C 34" – Logitech MX Keys – Logitech M705 – Jabra Evolve2 75
Racing SIM
GEAR: Sim-Lab GT1 EVO Sim Racing Cockpit + Integrated Vario Triple mount – Svive Racing D1 Seat – MSI 325CQRXF 32" x3 – Simagic Alpha Mini + Simagic GT4 (Dual Clutch) – CSL Elite Pedals V2 – Logitech K400 Plus
https://linustechtips.com/topic/1430172-pc-always-running-hot/#findComment-15389646
the temps I don't remember and to be safe I don't want to run anything in the meantime. but all temps were marked red/too hot by Speccy.
Closest case is Zalman S3 TG ATX, the actual case I just can't find anymore but this model seems to be pretty much exactly the same.
Also case looks way dustier than it is, dust has been cleaned out just need to wipe off the glass, and pls don't make fun of my cable management I was lazy 😞
https://linustechtips.com/topic/1430172-pc-always-running-hot/#findComment-15389654
Just wait until you see my cable management on my desk. It's inexistant xD. I don't ever see it though so it never bothers me but many YT'ers like Jaystwocents would be infuriated by my cable management 🙂
https://linustechtips.com/topic/1430172-pc-always-running-hot/#findComment-15389668
If you are not willing to test temperatures with a game or benchmark, it's going to be hard to help you. We need to know what the exact temps are for your CPU and GPU, to know what is causing the framedrops and stutters. Also, your PC will just thermal throttle. A quick rise to 100C does not harm anything. Just close whatever game or benchmark you have running.
GAMER
Home LAB
Racing SIM
https://linustechtips.com/topic/1430172-pc-always-running-hot/#findComment-15389703
