Hello guys,
I just bought a new case for a better airflow. It's the Lian Li Lancool-215. I have a ASRock B550M-ITX/ac mobo.
So... the case has a basic controller for the RGB on the two front fans and the Lianli logo but the issue is that they are not recognized.
I plugged the controller to the right header according to the board manual, it's a 3-pin cord. The fans are working, light is on, but i can't control it. I have no idea what i did wrong or what i'm missing. I tried unplugging it and redo it again, but nothing changed.
It's my first "RGB" components so i'm kinda lost  here.
I know i can't control the fan speed, which is fine by me, i just need to know if i can modify the colors.
Thanks a lot for your help !
https://linustechtips.com/topic/1430062-argb-issue/
3 minutes ago, YoungBlade said:
Not all motherboards have controls for the RGB built in. You may need to use a third party utility from the manufacturer to get control.
Here's a link to ASRock's Polychrome utility: https://download.asrock.com/Utility/RGB/PolychromeRGB(v2.0.109).zip
Hello !
Downloaded it and still nothing. It recognize the pins, but not the fans. I mean, nothing is happening when i change the setup.
https://linustechtips.com/topic/1430062-argb-issue/#findComment-15388762
12 minutes ago, Lorionlol said:
Hello !
Can you post some pictures and screenshots of what you're seeing? A picture of the connection on the motherboard and also a screenshot of the Polychrome utility?
You plugged the 3 pin ARGB plug into this header, yes?
https://linustechtips.com/topic/1430062-argb-issue/#findComment-15388768
