For any 30 series card, a 550w psu is risking it. For a 3060, I wouldn't go below a 650w. There are some cheap 650w units as well, like the evga bq 650 that is semi modular. i got mine for $50 bucks after tax and shipping, so just look for some good deals. It's always a good idea to go around 100-150 watts above what you need, and especially since the 30 series cards can spike up in power consumption (not the 3060 so much but the 3070, 3080, and 3090).
TL;DR: I would go with a 650w psu instead because its good to go around 100 watts higher than what you need, and its good headroom.
Specs: 11700 | RTX 3060 | 32gb 3200mhz | 1tb 970 + 2TB HDD | Lian Li O11D Mini X Black
I'm 15 and live in the US
https://linustechtips.com/topic/1430052-power-supply-help/#findComment-15388676
On a bad PSU, yes. A good high quality, not really.
I wouldn't recommend just based on wattage. The ASUS Tuf Bronze is a tier B PSU while the B1 doesn't show up on the list. I'd be more comfortable with the TUF Bronze here.
https://cultists.network/140/psu-tier-list/
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
https://linustechtips.com/topic/1430052-power-supply-help/#findComment-15388690
yeah i meant bq 650 lol
https://linustechtips.com/topic/1430052-power-supply-help/#findComment-15388696
So tier C?
Project Hot Box
Oppbevaring
https://linustechtips.com/topic/1430052-power-supply-help/#findComment-15388700
44 minutes ago, subjectx5 said:
Is the Asus tuf gaming 550w bronze good for a 3060?
It's fine - the TUF Bronze is mostly a Corsair CX (non-M) underneath
Anyway do you have a link to a webshop so that we can pick a better recommendation based on your budget?
https://linustechtips.com/topic/1430052-power-supply-help/#findComment-15388747
