My PC Config
Motherboard: M5A99FX Pro Rev 2.0
Processor: AMD FX 8320 Overclocked
Ram:  Corsair Vengeance  8GB
Graphics : ASUS GTX 550 Ti 1 GB Direct CU
PSU: Cooler Master 550w GX
I plan to upgrade  graphics  card to higher end card like GTX 600 series or 700 series my question is if i upgrade higher end  graphics  card my PSU is ok or i need to buy a new PSU
Pls list out my PSU capable higher  graphics  card  both AMD and Nvidia
Note: I use  graphics  card for render purpose [ 3Ds Max ]
https://linustechtips.com/topic/142965-graphics-card-help/
what is your budget ,and what monitor you use  720P /1080P /4k and do you game alot, and what kind of games you play  if you play free to play games  you dont realy need an beast card, but if play games like battlefield 3/4 crysis  or farcry a lot i should say spend a but more and be more future proof
and your 550 watt psu is enough   even if you  buy an 780TI  or R290
i always want to be future proof so i buy always top of the line  card and run it for 3/4 years if the card dont die  and sell my card and i buy again top of the line  so i dont have to upgrade every year /2 years.
but again what is your budget
do you want to upgrade  other components  ect.
let me know ;)
ps here you have an link from oc3dtv he uses an 450 watt psu with an 780ti
https://linustechtips.com/topic/142965-graphics-card-help/#findComment-1908842
let me know ;)
First thanks for u r  reply
Ya i play games too but mainly i need high  end graphics  card for rendering purpose and i am looking for 3 or 4 GB memory  graphics  card too
Budget 250 USD - 300 USD
At most 400 USD
U said my PSU able to  provide  power for 780 ti i am happy to hear that
U  listed  out some games like Farcry etc those games i already played
My monitor is 19" so max resolution  is 1680 x 1050 i plan to upgrade my monitor too but not now plan to buy a 8 K monitor
https://linustechtips.com/topic/142965-graphics-card-help/#findComment-1908943
let me know ;)
At most 400 USD
they go for an gtx 770 if 400 usd is the maximum  4GB  gtx 770 do you have  for  360 /380 usd on newegg
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127747
for example  other gtx 770 have 2 gb on board this one has 4 gb vram but  so price is higher here
i prefer Nvidia becouse i had many problems with amd  (ATI) back in the days  but maby i had bad luck with them
if you wanna trie AMD go for an R9 280X  that card compares with the 770
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121803
r9 280 X but this card is more power hungry  you will able to run it but be carfull with OC  cpu and gpu
the 770 is more power efficient and the one i send you has 1 gb more  vram than the 280x ;)
the 780 goes above 400 / 500 usd
https://linustechtips.com/topic/142965-graphics-card-help/#findComment-1909139
Thanks again for u r kind replay
Again my question is my PSU is capable or that's my question budget not a problem
if i buy 780ti or titan or quadro series di i need new PSU or current one OK
Please tell my my PSU[Cooler Master 550w GX] supporting  graphics  card only
https://linustechtips.com/topic/142965-graphics-card-help/#findComment-1909199
if you go 780 titan/ quadro it will power them but then go fdor an other other cpu if you realy want to go for editing you should go for an i7 if you r just gaming  you will be fine with that psu and cpu  with an 780 /ti/ titan
but if you realy want to be shure  go to the PSU section  from this forum or OC3D forums  post all the hardware you have in your pc
dvd drives / blueray  hard discs  ssds  coolers how many fans every thing you plugged in to you psu and if you  cpu is overclocked  how  many volts you use  and how many volts you use on the ram
im not an expert on psu's but  if you realy want to be safe and have a bit room  for your psu i tink you will  end up with 600 /650 watts  if you wanna overclock and stuff
thats the only thing i can say to you
just as i sayd if you have an small overclock on ur cpu  you will be able to run an 770 but dont overclock it then that may put to mutch stress on your psu
but as far as i know  you will be ready  for an 780ti/780 /770 without overclocking it!  but if you have your cpu bad ass overclocked with high voltages you maby get to run your cpu at stock speeds and stock voltages  but as i say i dont know how hight your cpu is overclocked and how many volts you use  ;)
https://linustechtips.com/topic/142965-graphics-card-help/#findComment-1909294
well , if you go GTX 660/670 ,i think the psu will do just fine because Cooler master are very known on Making  very good PSUs , GTX 760/770 ,huuum ,you would be better to upgrade to 600~700W ,just to shill and not keep na eye on it worrying about it running Very hot at 90% Load
 Crust : Intel Core i5 4690K @ 4.4Ghz 1.45v  |  MotherboardMSI Z97 MPower  |  Fruity FillingMSI GTX 960 Armor 2Way-SLI |  CoolingNoctua NH-D15  |  RAM : 16GB Corsair Vengeance 1600Mhz | Storage : 2xSamsung 840 EVO 500GB SSDs Raid-0  |  Power Supply : Seasonic X-Series 1250W 80+Gold  |  Monitor : Dell U2713HM 27" 60Hz 1440p  |
https://linustechtips.com/topic/142965-graphics-card-help/#findComment-1909364
