Hi, I was wondering if someone could help me overclock my RAM to 3600MHz and processor to 4.2 GHz. I listed my computer specs below.
Also, is it safe to turn on NVIDIA GeForce auto tuning?
My current GPU temperature is about 54 degrees on idle and 85-86 degrees while playing AAA games.
My CPU temperature is stable at 45 degrees on idle and about 76 degrees while gaming AAA games.
Processor: Ryzen 7 3800x
Ram: Kingston Hyper X fury ddr4 RGB 4 sticks of 8 GB (3200MHz)
Motherboard: Gibabyte Aorus Elite
GPU: INNO3D RTX 3060
Cooler: ID Cooling Aura flow X360
PSU: Dark Flash GS 650 650W (Bronze certified)
https://linustechtips.com/topic/1429076-need-help/
Don't OC your CPU like that. You should instead look into "PBO". Essentially, with Ryzen, the best way to get the more performance out of the chips is to remove power and thermal limits while reducing the voltage, which allows the CPU to clock itself higher. As an example, with my 5600G I have PBO set to "Advanced" with the sub-settings set to "auto" or "motherboard" and an all-core negative offset of 25. This provides a significant performance boost, and was relatively easy to setup.
RAM overclocking can be a very involved process. Here is a basic outline of that process to get you started.
  • Make a memtest86 bootable USB.
  • Test your RAM at it's standard XMP settings.
  • Increase the speed without touching voltage or timings in small increments and test between each step.
  • When you start getting errors in memtest86, try increasing the DRAM voltage by small steps until you get stability, or until you reach 1.5V, whichever comes first.
    • If 1.5V isn't stable at the speed/timings combo, try increasing your timings until you can pass memtest86.
  • Keep going until you find the best combo of speed/timings that your system can achieve.
  • Use HCI memtest, Linpack, and/or Prime95 to test for stability.
BabyBlu.2 (Primary):
  • CPU: AMD Ryzen 5 9600X
  • Motherboard: Asus ROG STRIX B650E-F
  • RAM: G.Skill Flare X5 64GB (2x32GB) DDR5-6000 CL30 @ 6400MHz 30-40-40-96
  • GPU: MSI RTX 2080 Sea Hawk EK X, 2100MHz core, 8000MHz mem
  • Case: Phanteks Evolv X
  • Storage: XPG SX8200 Pro 2TB, 3x ADATASU800 1TB (RAID 0), Samsung 970 EVO Plus 500GB
  • PSU: Corsair HX1000i
  • Display: MSI MPG341CQR 34" 3440x1440 144Hz Freesync, Dell S2417DG 24" 2560x1440 165Hz Gsync
  • Cooling: Custom water loop (CPU & GPU), Radiators: 1x140mm(Back), 1x280mm(Top), 1x420mm(Front)
  • Keyboard: Corsair Strafe RGB (Cherry MX Brown)
  • Mouse: MasterMouse MM710
  • Headset: Corsair Void Pro RGB
  • OS: Windows 11 Pro
Roxanne (Wife Build):
  • CPU: AMD Ryzen 5 7600
  • Motherboard: Gigabyte B650I AORUS ULTRA
  • RAM: G.Skill Flare X5 32GB (2x16GB) DDR5-6000 @ 6000MHz 30-38-38-96
  • GPU: EVGA GTX 1080 FTW2 w/ LM
  • Case: Cooler Master MasterBox NR200
  • Storage: Samsung 850 EVO 250GB, Samsung 860 EVO 1TB, Silicon Power A80 2TB NVME
  • PSU: Corsair SF850L
  • Display: Dell Alienware AW3420DW GSync
  • Cooling: Arctic Liquid Freezer II 280mm
  • Keyboard: GMMK TKL(Kailh Box White)
  • Mouse: Glorious Model O-
  • Headset: SteelSeries Arctis 7
BigBox (HTPC):
  • CPU: Ryzen 5800X3D
  • Motherboard: Gigabyte B550i Aorus Pro AX
  • RAM: Corsair Vengeance LPX 2x8GB DDR4-3600 @ 3600MHz 14-14-14-28
  • GPU: MSI RTX 3080 Ventus 3X Plus OC, de-shrouded, LM TIM, replaced mem therm pads
  • Case: Fractal Design Node 202
  • Storage: SP A80 1TB, WD Black SN770 2TB
  • PSU: Corsair SF600 Gold w/ NF-A9x14
  • Display: Samsung QN90A 65" (QLED, 4K, 120Hz, HDR, VRR)
  • Cooling: Thermalright AXP-100 Copper w/ NF-A12x15
  • Keyboard/Mouse: Rii i4
  • Controllers: 4X Xbox One & 2X N64 (with USB)
  • Sound: Denon AVR S760H with 5.1.2 Atmos setup.
Harmonic (NAS/Game/Plex/Other Server):
  • CPU: Intel Core i7 6700
  • Motherboard: ASRock FATAL1TY H270M
  • RAM: 64GB DDR4-2133
  • GPU: Intel HD Graphics 530
  • Case: Fractal Design Define 7
  • HDD: 3X Seagate Exos X16 14TB in RAID 5
  • SSD: Inland Premium 512GB NVME, Sabrent 1TB NVME
  • Optical: BDXL WH14NS40 flashed to WH16NS60
  • PSU: Corsair CX450
  • Display: None
  • Cooling: Noctua NH-U14S
  • Keyboard/Mouse: None
  • 2.5Gb NIC
  • OS: Windows 10 Pro
NAS:
  • Synology DS216J
  • 2x8TB WD Red NAS HDDs in RAID 1. 8TB usable space
https://linustechtips.com/topic/1429076-need-help/#findComment-15382138
