Hello all,
I'm planning to build my first computer in a couple weeks. I've put together a complete parts list and I'm looking for some general feedback on it. My budget is ~$2000 CAD. I'm located in Canada. I'm going to be using this computer primarily for gaming. I enjoy a large variety of games, mainly single-player (I don't play any sort of competitive games). I also intend to use the PC for programming, virtual machines, photo editing, etc; though that is not the focus. As you can tell from the parts list, I'm targeting 1440p gaming. My peripherals are already purchased. One thing to note: I primarily use Linux, that is main motivation for going AMD over Nvidia.
https://ca.pcpartpicker.com/list/NYxshk
Thanks for the help!
https://linustechtips.com/topic/1428539-looking-for-feedback-on-first-build/
maybe go for a 750w and some extra storage. Definitly a 750w to be safe (and for upgradeability). I would get a 256 or 500 gig drive for booting into windows, because it is generally better to have windows on a seperate drive.
Specs: 11700 | RTX 3060 | 32gb 3200mhz | 1tb 970 + 2TB HDD | Lian Li O11D Mini X Black
I'm 15 and live in the US
1TB will probably give you issues down the road sooner than you think. Might be worth getting a 2TB drive from a brand other than Samsung to save money ei. Crucial/Kingston. Rest looks fine to me, as @cat milker said, 750 watts would give you more room to work with but it's not a priority in my opinion. I have some minor concerns for high frame rate 1440p gaming with a 6700xt running Linux.
Could you go into a bit more detail on your "minor concerns"? I was planning to just go with 1TB for now, as storage is easy to upgrade later. However, if you think it's wise, I'll take a look at higher capacity drives.
Would you recommend the 750w version of the power supply I have on the parts list, or a different brand/model?
PCPartPicker Part List
CPU: AMD Ryzen 7 5700X 3.4 GHz 8-Core Processor  ($377.50 @ shopRBC)
CPU Cooler: Scythe Fuma 2 Rev.B 39.44 CFM CPU Cooler  ($89.18 @ Amazon Canada)
Motherboard: MSI B550M PRO-VDH WIFI Micro ATX AM4 Motherboard  ($149.99 @ Best Buy Canada)
Memory: G.Skill Ripjaws V 16 GB (2 x 8 GB) DDR4-3600 CL16 Memory  ($104.99 @ Memory Express)
Storage: Western Digital WD_BLACK SN750 SE 1 TB M.2-2280 NVME Solid State Drive  ($119.99 @ Newegg Canada)
Case: Lian Li LANCOOL 215 ATX Mid Tower Case  ($123.59 @ Vuugo)
Power Supply: Corsair RMx (2018) 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($138.05 @ Vuugo)
Monitor: LG 27GN800-B 27.0" 2560x1440 144 Hz Monitor  ($389.99 @ Amazon Canada)
Custom: AMD Radeon RX 6700 XT ($605.00)
Total: $2098.28
Generated by PCPartPicker 2022-05-02 09:39 EDT-0400
