Hi, I want to upgrade my memory modules. My current ones are 2666MHz 2x8 gb stick and i have heard that amd ryzen CPUs doesn't like low speed modules. So I want to change them but I don't know what speed should be sufficient for me the most. My motherboard is a Gigabyte b450 aorus pro and my CPU is a ryzen 5 3600 non-X version. Thanks for the help.
https://linustechtips.com/topic/1428519-help-needed-for-choosing-memory-module/
Yes, and no. It depends on what you're trying to do with more/faster RAM. Without knowing much about what you're trying to improve on, I would recommend 3200MHz RAM. 3200MHz RAM is one of the highest speeds that b450 motherboards originally supported. 32GB 3200MHz RAM would be the sweet spot for your build.
Edited by GeorgeMKane
Am I still to create the perfect system?! ~ Clu
Keep your expectations low, boy, and you will never be disappointed. ~ Kratos
