Budget (including currency): €4500
Country: Germany
Games, programs or workloads that it will be used for: Gaming, mostly strategy games like Crusader Kings 3, Stellaris, Civ 6 but some AAA gaminf as well
Other details I am looking for a system that will enable me to play games no matter the FPS or graphic quality for as long as possible before needing to update, hence why I am going with a 12900k and 2080Ti, this will be a completely clean build I have no parts right now, any advice especially concerning CPU cooling and case fans would be welcome.
https://linustechtips.com/topic/1426332-pc-build-advice/
Country: Germany
Pretty much every component needs changing tbh. Phew, that's a doozy
CPU-AMD Ryzen 7 7800X3D GPU- Gigabyte WindForce SFF RTX 5070ti MOBO-ASUS ROG Strix B650E-E Gaming Wifi RAM-32gb G.Skill Trident Z5 Neo DDR5 6000cl30 STORAGE- 2TB Samsung 990 Pro PCIE4 NVME x2 PSU-Corsair RM1000x Shift COOLING-Lian Li GA II Lite 360mm with 3x Lian Li P28 + 4 Lian Li TL120 (Intake) CASE-Phanteks NV5 MONITORS-Samsung G61 QD-OLED 1440p 240hz +Gigabyte G24F 1080p 180hz PERIPHERALSVaxee XE-S+Padsmith Crucible Mousepad+Monsgeek M1 V5 TMR+Autonomous ErgoChair+ AUDIO-Audient iD4 Mk II + Rode NTH100
https://linustechtips.com/topic/1426332-pc-build-advice/#findComment-15362558
Country: Germany
Here:
$1000 cheaper without losing any performance really. WAYYYYYYYYYYYYYY better cooling with fractal torrent. Two of the best fans in the world with the a12x25s as bottom intake. Less overpriced cpu, board. No crappy useless DDR5 ram. You can buy windows from a cdkey website for like 20 bucks. 3080ti not worth it over vanilla 3080. Also I found a far superior power supply for cheaper. Save the extra 2k for upgrades next gen, gas, go take your girl out, etc.
PCPartPicker Part List: https://de.pcpartpicker.com/list/Tn7d9r
CPU: Intel Core i7-12700K 3.6 GHz 12-Core Processor  (€413.99 @ Mindfactory)
CPU Cooler: Noctua NH-D15 chromax.black 82.52 CFM CPU Cooler  (€109.90 @ Amazon Deutschland)
Motherboard: MSI PRO Z690-A DDR4 ATX LGA1700 Motherboard  (€194.94 @ Amazon Deutschland)
Memory: Crucial Ballistix RGB 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory  (€144.90 @ Alza)
Storage: Samsung 970 EVO Plus 2 TB M.2-2280 NVME Solid State Drive  (€202.99 @ Mindfactory)
Video Card: Palit GeForce RTX 3080 10GB 10 GB GamingPro Video Card  (€977.99 @ Mindfactory)
Case: Fractal Design Torrent Compact ATX Mid Tower Case  (€165.85 @ Computeruniverse)
Power Supply: Corsair RMx (2021) 1000 W 80+ Gold Certified Fully Modular ATX Power Supply  (€172.90 @ Alza)
Case Fan: Noctua NF-A12x25 PWM chromax.black.swap 60.09 CFM 120 mm Fan  (€32.90 @ Amazon Deutschland)
Total: €2449.26
Generated by PCPartPicker 2022-04-21 20:08 CEST+0200
https://linustechtips.com/topic/1426332-pc-build-advice/#findComment-15362571
Country: Germany
Alternatively, you could get the 5800x3d. Not available in germany yet but is the best cpu for strategy games. I would then get the b550 unify x motherboard(the one with two dimm slots) and get some good 3800 cl14 ram and tighten the timings as much as possible
https://linustechtips.com/topic/1426332-pc-build-advice/#findComment-15362578
Country: Germany
Alternate AMD build:
PCPartPicker Part List: https://de.pcpartpicker.com/list/W78mrD
CPU: AMD Ryzen 7 5800X3D 3.4 GHz 8-Core Processor  (€449.99 @ Mindfactory) OUT OF STOCK
Motherboard: MSI MEG B550 UNIFY-X ATX AM4 Motherboard  (€261.06 @ Amazon Deutschland)
Memory: G.Skill Trident Z RGB 16 GB (2 x 8 GB) DDR4-4000 CL14 Memory  (€255.85 @ Computeruniverse)
Total: €2762.33
Generated by PCPartPicker 2022-04-21 20:23 CEST+0200
https://linustechtips.com/topic/1426332-pc-build-advice/#findComment-15362586
