I have a lot of lag when playing Titanfall 3D. Can anybody guide me in the right direction to help me resolve this issue. Here is my build and i use NVIDIA 3D Vision 2 Wireless Glasses Kit.
CPU: Intel Core i7-4770K 3.5GHz Quad-Core Processor ($309.99 @ NCIX US)
CPU Cooler: Corsair H100i 77.0 CFM Liquid CPU Cooler ($89.99 @ Amazon)
Motherboard: MSI Z87 MPOWER MAX AC ATX LGA1150 Motherboard ($205.99 @ SuperBiiz)
Memory: G.Skill Trident X Series 32GB (4 x 8GB) DDR3-2400 Memory ($360.98 @ Newegg)
Storage: Samsung 840 Pro Series 256GB 2.5" Solid State Disk ($199.99 @ Amazon)
Video Card: Gigabyte GeForce GTX 760 4GB Video Card ($298.99 @ SuperBiiz)
Case: Cooler Master Storm Stryker (White) ATX Full Tower Case ($139.99 @ Newegg)
Power Supply: SeaSonic G 550W 80+ Gold Certified Semi-Modular ATX Power Supply ($79.99 @ Amazon)
Optical Drive: LG GH24NS95 DVD/CD Writer ($21.95 @ Newegg)
Operating System: Microsoft Windows 8.1 - 64-bit (OEM) (64-bit) ($94.99 @ Best Buy)
Monitor: Asus VG248QE 144Hz 24.0" Monitor ($269.99 @ NCIX US)
Total: $2072.84
https://linustechtips.com/topic/142610-help-3d-lag/
Played 3D already halves your framerate and you don't have a really powerfull GPU (if you went for a gaming build with this one, I think you might have spent some money on the cpu that you could have used for the gpu). I recommend using the Geforce Experience, although I don't know if it can optimise for 3D.
i5 4670k - MSI GTX 770 gaming - Fractal design define R4 (windowed) - MSI Z87-G45 gaming - be quiet! Dark Rock Pro 2 - Corsair vengeance 8 gb (lp) - WB black 1tb - 256GB SSD - Corsair TX 750M - Ducky Shine 3
https://linustechtips.com/topic/142610-help-3d-lag/#findComment-1903753
