Sorry but this is going to be longer than recommended so I can list everything I have done so far...
My original config was....
Aorus X570 Pro Motherboard with Ryzen 7 5800X and 32GB Gskill Trident Z Neo 3600 RAM
2TB Sabrent Rocket 4 nvme drive with a 1TB Western Digital Black nvme, both plugged into mobo
Inno 3D GTX 1080
Sound Blaster AE-9
TP-Link Wifi-AC internal card connected to internal usb header
EKWB Watercooling loop with EK Fans connected to motherboard (seperate pump/res)
2 x Corsair red LED Fans
Corsair AX760i PSU
Phanteks Enthoo Pro Case.
Windows 10
Corsair K70 Keyboard
Logitech G502 Mouse
BenQ BL3200 monitor
Sound System connected to PC via analogue cables
Pioneer SC-LX72 AV Receiver
B&W Front and Center Speakers
Logitech satellites
REL T7/x Subwoofer
I am based in the United Kingdom with 230v mains power.
Everything running from one extension cord with cables supplied by manufacturer
Everything was awesome. No issues at all.
I have rebuilt this system in a Lian Li O11 D Evo case and changed the PSU to a Seasonic GX-1000 and the GPU to a KFA2 3080Ti while changing all the fans to Corsair iCUE RGB
Windows was not reinstalled as no other components were changed
Now when I launch into games, once the GPU starts rendering objects on screen you can hear noise from the speakers that changes depending on the GPU load, it is not a constant tone, it is high pitched and fluctuates rapidly.  It is also barely audible when moving the mouse on desktop.
I have disconnected/removed everything from the case so that the system now consists of
Motherboard, CPU, RAM and the nvme drives
Onboard audio
Reinstalled the GTX 1080 (even tried an old GTX780)
Gone Back to the Corsair PSU
NO Fans at all briefly with the pump still running
Wired internet
Just the case power switch connected to the motherboard
nade sure to use plain screws and scrubbed the case down to bare metal at the PSU mounting points to ensure the PSU is grounded.
Ive disconnected the Display Port able and gone through every possible speaker/interconnect cable combo I can (down to single speaker) and after all of that still the noise persists!!
Unfortunately I cant rebuild in the Phanteks case as I gave it to a visiting family member and I don't have an amd air cooler to completely eliminate the loop.
Connecting to the amp via optical (both onboard and AE-9) gets rid of the issue but this is not an acceptable solution as the sound quality is poor compared to the analogue connections.  I've also connected a bluetooth speaker that has a 3.5mm input jack to both onboard and the AE-9 and the noise was not present while on battery power and also when connected to the mains charger
I've checked every socket available in the room with a tester and all returned correct wiring readouts.
To say I'm baffled is an understatement - why would a known good config suddenly go "bad" like this after moving to a new case??
Apologies again for the long post but felt it was necessary to provide a full account of the situation to cover off as many questions as possible and hopefully get to a resolution quicker.
Any suggestions for next steps (that dont cost money ideally) would be massively appreciated.
https://linustechtips.com/topic/1425763-ground-loop-after-changing-case-and-psu/
This does not sound like a ground loop. It sounds more like EMI. Given what you have tried already, I'd guess that the geometry and material of the new case is probably making it more pronounced some how.
My best suggestion would be to switch to an external DAC and Amp.
Also, go into your BIOS and make sure any "Spread Spectrum" settings are enabled.
BabyBlu.2 (Primary):
  • CPU: AMD Ryzen 5 9600X
  • Motherboard: Asus ROG STRIX B650E-F
  • RAM: G.Skill Flare X5 64GB (2x32GB) DDR5-6000 CL30 @ 6400MHz 30-40-40-96
  • GPU: MSI RTX 2080 Sea Hawk EK X, 2100MHz core, 8000MHz mem
  • Case: Phanteks Evolv X
  • Storage: XPG SX8200 Pro 2TB, 3x ADATASU800 1TB (RAID 0), Samsung 970 EVO Plus 500GB
  • PSU: Corsair HX1000i
  • Display: MSI MPG341CQR 34" 3440x1440 144Hz Freesync, Dell S2417DG 24" 2560x1440 165Hz Gsync
  • Cooling: Custom water loop (CPU & GPU), Radiators: 1x140mm(Back), 1x280mm(Top), 1x420mm(Front)
  • Keyboard: Corsair Strafe RGB (Cherry MX Brown)
  • Mouse: MasterMouse MM710
  • Headset: Corsair Void Pro RGB
  • OS: Windows 11 Pro
Roxanne (Wife Build):
  • CPU: AMD Ryzen 5 7600
  • Motherboard: Gigabyte B650I AORUS ULTRA
  • RAM: G.Skill Flare X5 32GB (2x16GB) DDR5-6000 @ 6000MHz 30-38-38-96
  • GPU: EVGA GTX 1080 FTW2 w/ LM
  • Case: Cooler Master MasterBox NR200
  • Storage: Samsung 850 EVO 250GB, Samsung 860 EVO 1TB, Silicon Power A80 2TB NVME
  • PSU: Corsair SF850L
  • Display: Dell Alienware AW3420DW GSync
  • Cooling: Arctic Liquid Freezer II 280mm
  • Keyboard: GMMK TKL(Kailh Box White)
  • Mouse: Glorious Model O-
  • Headset: SteelSeries Arctis 7
BigBox (HTPC):
  • CPU: Ryzen 5800X3D
  • Motherboard: Gigabyte B550i Aorus Pro AX
  • RAM: Corsair Vengeance LPX 2x8GB DDR4-3600 @ 3600MHz 14-14-14-28
  • GPU: MSI RTX 3080 Ventus 3X Plus OC, de-shrouded, LM TIM, replaced mem therm pads
  • Case: Fractal Design Node 202
  • Storage: SP A80 1TB, WD Black SN770 2TB
  • PSU: Corsair SF600 Gold w/ NF-A9x14
  • Display: Samsung QN90A 65" (QLED, 4K, 120Hz, HDR, VRR)
  • Cooling: Thermalright AXP-100 Copper w/ NF-A12x15
  • Keyboard/Mouse: Rii i4
  • Controllers: 4X Xbox One & 2X N64 (with USB)
  • Sound: Denon AVR S760H with 5.1.2 Atmos setup.
Harmonic (NAS/Game/Plex/Other Server):
  • CPU: Intel Core i7 6700
  • Motherboard: ASRock FATAL1TY H270M
  • RAM: 64GB DDR4-2133
  • GPU: Intel HD Graphics 530
  • Case: Fractal Design Define 7
  • HDD: 3X Seagate Exos X16 14TB in RAID 5
  • SSD: Inland Premium 512GB NVME, Sabrent 1TB NVME
  • Optical: BDXL WH14NS40 flashed to WH16NS60
  • PSU: Corsair CX450
  • Display: None
  • Cooling: Noctua NH-U14S
  • Keyboard/Mouse: None
  • 2.5Gb NIC
  • OS: Windows 10 Pro
NAS:
  • Synology DS216J
  • 2x8TB WD Red NAS HDDs in RAID 1. 8TB usable space
Have you checked the extension cord?
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
  • 7 months later...
