I was just wondering what is some good smooth and clean paint that would generally retain the texture of my case. Especially the front of the Fractal R4
OS - Windows 8.1 Motherboard - ASUS M5A99FX Pro R2.0 Processor - AMD FX 8350 Black Edition RAM - 16GB 2x8 Crucial Ballistix Sport Graphics Card - Gigabyte Windforce 2 OC GTX 660 Power Supply - Corsair CX750M CPU Cooler - NZXT Kraken X60 Wireless Adapter - ASUS PCE-N15 PCI-E Adapter Fans - x3 Masscool blue LED 120mm Fans Case - Fractal Design Define R4
Monitor - Dell S2230MX 21.5-inch Keyboard - Logitech G105 Mouse - Logitech G602 Speakers - Logitech Z130 Headsets/Headphones - Tt eSports Shock, AKG K240, California Headphones Laredo Phone - iPhone 4S
https://linustechtips.com/topic/14252-good-paint-for-case-modding/
The good paints tend to be acrylic automotive ones that require an air compressor and a cupgun. The only other option are the spray cans. Its really easy to tell the difference by looking.
If you don't have a cupgun/aircompressor you could all ways pay someone to powder coat your machine.
Thanks guys. I was thinking that I should use automotive paint as well. I will give those a try!
i use the SEM black trim paint for a close sheen match on my Arc Midi.
the texture really can't  be duplicated other than powder-coating or
paint mixing. because the P-Coating FD uses 30-35μm which gives the
orange peel texture and uses low baking temps so not to warp the thin
steel.
airdeano
