Just now, RONOTHAN## said:
No, all coolers available on the market today are compatible with AM4 (the socket and mounting hardware used by that board) out of the box. You only need to worry about it if you went 12th gen intel
ok thanks was just worried cuz pc part picker said it may be an issue
Would depend on when the cooler was manufactured, but not likely to be a problem at this stage. AM4 has been out a good while now.
I don't badmouth others' input, I'd appreciate others not badmouthing mine. *** More below ***
MODERATE TO SEVERE AUTISTIC, COMPLICATED WITH COVID FOG
Due to the above, I've likely revised posts <30 min old, and do not think as you do.
THINK BEFORE YOU REPLY!
