I'm having trouble with Afterburner that it resets my GPU fans to 23% after a restart/shutdown. The only temporary solution I've come up with is to Uninstall Afterburner, uninstall the graphics drivers, perform a clean install of the drivers and afterburner then I have manual control again. Any solutions?
https://linustechtips.com/topic/1424722-gpu-fan-issue/
Per default, afterburner doesn't apply custom settings on boot. You can click the little gear icon and click on manual next to the fan slider and then hit apply. This way, your custom curve is applied. Or just click the windows icon. Then whatever you set will be set on boot automatically
https://linustechtips.com/topic/1424722-gpu-fan-issue/#findComment-15351015
That doesn't work. The slider will still be stuck at 23%. If I move it it will just default back to 23%
https://linustechtips.com/topic/1424722-gpu-fan-issue/#findComment-15351030
