So first off I am not sure if this is the right place on the forum, or even the right forum at all. I have a Mace 80357 motion sensor and I have an idea but im not sure if it will work, since I have no background working with electronics. The motion sensor has a LED light that tells you whether it detects motion or not and I was wondering if I could set it up with some kind of wireless send/receive setup to send a signal to power a light somewhere like my room or office.
Thanks!
-Xavier
My PC:
CPU: Xeon E3 1230 V3(Haswell) @ 3.7GHz Motherboard: AsRock B85M-ITX RAM: 8GB Corsair Vengeance LP Blue @ 1600MHz Storage: Intel 520 Series 120(Boot), Seagate Barracuda 500GB @ 7200RPM, Western Digital Caviar Green 1TB @ 5400RPM GPU: ZOTAC GTX 970 @ 1.4GHz Case: Node 304 Power Supply: CX430
https://linustechtips.com/topic/142450-motion-sensor-mod/
I googled that for ya, and that motion sensor is designed to work with a complete home security system with a central hub and all, so it probably won't work. Maybe you can hack it or something, but it will probably be difficult and not worth it.
Main Rig: Cpu: Intel Core i7 4790k CPU Cooler: NH_d15 GPU: Gigabyte Radeon HD7970 Windforce III MOBO: Msi Z97 Gaming 5 RAM: HyperX Fury 1600 8gb white SSD: Samsung 840 evo 250gb PSU: Corsair CX750M Case: NZXT H630 white
PC peripherals: Monitor: Samsung Syncmaster T27B550 Keyboard: Logitech G105 Mouse: Logitech G700s Headphones: Logitech G430
https://linustechtips.com/topic/142450-motion-sensor-mod/#findComment-1916369
