4pin case fans
Go to solution Solved by -rascal-,
If you are referring to System_fan1 / 2 / 3 on your Gigabyte GA-Z87-D3HP, then, yes.
They are PWM controlled (4-pin) fan connections, and they will increase / decrease fan speed as necessary.
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/142336-4pin-case-fans/#findComment-1900832
