Recently noticed that a large portion of my gaming library which were previously running excellent are now virtually unplayable.
Warzone , Horizon Zero Dawn etc were running at max resolution , max settings and running 60-70+fps consistently. Consistently getting 2250 points in Heavens 4 benchmark software.
Several other games would detect and default to higher or ultra settings , which they still do even now but the performance of the above mentioned games is terrible , warzone is stuttering in the main menu , running at 1-5 fps in matches.
Horizon runs at 20 fps when set to lowest settings but even then the lighting and textures look like 2005.
All is still repeated on full game and driver reinstalls.
I have noticed that some games seem entirely unaffected such as frostpunk , that runs at the same quality/fps as before
While running Heavens 4 benchmark software again I am still getting about the same score, any idea what the cause is?
The only change that i can think of is moving from (1 SSD and 1 HDD as different volumes) to (2 SSD as shared volume) for the main game library, but the issue persists when running off the main boot drive which separate
I have included the system specs output from Speccy for more details on the hardware
Any assistance to even start trying t figure out the problem would be greatly appreciated.
system_specs-detailed.txt
I would say it over and over again... if you are not running a 12th gen Intel cpu (alderlake) DON'T NEVER EVER UPGRADE TO 11 in words ELEVEN... Stay on 10.
I gues there are issues again in regard of win 11, drivers, core parts...
Main System:
Anghammarad : Asrock Taichi x570, AMD Ryzen 7 5800X @4900 MHz. 32 GB DDR4 3600, some NVME SSDs, Gainward Phoenix RTX 3070TI
System 2 "Igluna" AsRock Fatal1ty Z77 Pro, Core I5 3570k @4300, 16 GB Ram DDR3 2133, some SSD, and a 2 TB HDD each, Gainward Phantom 760GTX.
System 3 "Inskah" AsRock Fatal1ty Z77 Pro, Core I5 3570k @4300, 16 GB Ram DDR3 2133, some SSD, and a 2 TB HDD each, Gainward Phantom 760GTX.
On the Road: Acer Aspire 5 Model A515-51G-54FD, Intel Core i5 7200U, 8 GB DDR4 Ram, 120 GB SSD, 1 TB SSD, Intel CPU GFX and Nvidia MX 150, Full HD IPS display
Media System "Vio": Aorus Elite AX V2, Ryzen 7 5700X, 64 GB Ram DDR4 3200 Mushkin, 1 275 GB Crucial MX SSD, 1 tb Crucial MX500 SSD. IBM 5015 Megaraid, 4 Seagate Ironwolf 4TB HDD in raid 5, 4 WD RED 4 tb in another Raid 5, Gainward Phoenix GTX 1060
(Abit Fatal1ty FP9 IN SLI, C2Duo E8400, 6 GB Ram DDR2 800, far too less diskspace, Gainward Phantom 560 GTX broken need fixing)
Nostalgia: Amiga 1200, Tower Build, CPU/FPU/MMU 68EC020, 68030, 68882 @50 Mhz, 10 MByte ram (2 MB Chip, 8 MB Fast), Fast SCSI II, 2 CDRoms, 2 1 GB SCSI II IBM Harddrives, 512 MB Quantum Lightning HDD, self soldered Sync changer to attach VGA displays, WLAN
I've been running Win 11 on my 10900K and 2070 Super for the last week without issue so far
 With all the Trolls, Try Hards, Noobs and Weirdos around here you'd think i'd find SOMEWHERE to fit in!
