EVGA GTX760 Superclocked (ACX) - i5 4570 - 8GB DDR3 - 1TB Western Digital Caviar Blue - Corsair CX500 - NZXT Source 210(Black)  - 1x 120mm - Valley Bench http://imgur.com/J4EJnvV
https://linustechtips.com/topic/142266-bricked-gpu/#findComment-1899227
How did u do it man, i get various errors and i am now selling it as bricked lol. I am so fustrated would like to get it working again. My card won't detect and i get some adapter error.
Did you try using the bios switch? I used this guide as it was more specific in regards to the 6950.
http://www.tomshardware.com/forum/345474-33-6950-6970-failed-bios-flash#.
Try the instructions listed on post #5 by "draven501." For his step 7 "1.atiflash.exe -f -p 0 bios.rom -scansii" it should be "atiflash.exe -f -p 0 bios.rom -scansii"
i7 4770K @ 4.5GHZ, NH-D14, Kingston HyperX Black 8GB, Asus Z87-A, Fractal Design XL R2, MSI TF IV R9 280x, BTFNX 550G
https://linustechtips.com/topic/142266-bricked-gpu/#findComment-1904508
Do you have a dual bios switch on the card like this:
If you do you could switch to the working bios and boot your system up and when you are ready for flashing just switch the bios switch to the broken bios and flash it.
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
https://linustechtips.com/topic/142266-bricked-gpu/#findComment-1906237
No unfortunately it does not have a dual bios switch. I was just stupid and decided to flash it. I tried to flash it back to its original bios but it does not recognize the card in my slot. The only solution i found was to short out the bios using a wire which i don't want to risk since i just built a new rig and don't want any other components to go tits up. I might just get the 780 ti if nothing else works, but if you do know another solution please tell.
https://linustechtips.com/topic/142266-bricked-gpu/#findComment-1909300
If you have integrated graphics you might be able to boot into your os using integrated graphics and flash it.
https://linustechtips.com/topic/142266-bricked-gpu/#findComment-1913362
