Wi-Fi extender questions (HELP PLS)
Amer
Is it better/faster/less ping if I took Intetnet via Ethernet cable directly from the router or from a wifi extender?
Cheese
Or is it all the same?
Cheese
Yes direct from a router to your PC? Yes but it won't improve internet speed maybe a more stable internet
So it’ll probably won’t always be stable if I used the extender right
Cheese
You can use an Ethernet cable from the wifi extender and it will only be fast as your wireless speeds can go up to. It should be stable.
Quote me for the answer and please Mark As Solution if I solved your problem
What I need help with rn
Best pc guides
Not if the extender is connected to the main router via WiFi, it can still suffer the same stability problems.  Granted, less likely than if you're connecting to the extender over WiFi, but connected over cable to the router is the only guaranteed stable connection.
Router:  Intel N100 (pfSense) WiFi6: Zyxel NWA210AX (1.7Gbit peak at 160Mhz)
WiFi5: Ubiquiti NanoHD OpenWRT (~500Mbit at 80Mhz) Switches: Netgear MS510TXUP, MS510TXPP, GS110EMX
ISPs: Zen Full Fibre 900 (~930Mbit down, 115Mbit up) + Three 5G (~800Mbit down, 115Mbit up)
