Budget (including currency): allready ordered
Country: Austria
Games, programs or workloads that it will be used for: fps
https://linustechtips.com/topic/1422119-fan-orientation/
Country: Austria
So I want to put the fans of the 4000x by corsair at the config to at front 3(rad) at back is that good?
https://linustechtips.com/topic/1422119-fan-orientation/#findComment-15332874
11 minutes ago, Deprssedgamer said:
Yeah Probably put it either on the front or the top probably shouldnt put it in the back
Rad on top as exhaust is ideal.
https://linustechtips.com/topic/1422119-fan-orientation/#findComment-15332901
