Budget not stupidly cheap but not stupidly expensive eg. 4000 and above:
Country:uk
Games, programs or workloads that it will be used for: minecraft-servers,mods,shaders Valorant and other popular games as well adobe premier pro and other editing applications streaming software
Other details I want it to run my stream and mods crystal clear and a good fps on the stream
https://linustechtips.com/topic/1422007-help-needed-with-pc-build/
4 minutes ago, BOB BISKET said:
Budget not cheap but not stupidly expensive eg. £4000 and above:
Country:uk
I am looking for a pc and I need some expert advice I mainly will use a pc for gaming (minecraft, gta, valorant) and other popular games but I also stream and make YouTube videos run my games streaming and edit using my adobe applications should I get a Mac studio or a pc if a pc please advise thanks you
PCPartPicker Part List
CPU: Intel Core i7-12700F 2.1 GHz 12-Core Processor  (£299.77 @ CCL Computers)
CPU Cooler: Deepcool AK620 68.99 CFM CPU Cooler  (£50.97 @ Technextday)
Motherboard: MSI PRO B660M-A DDR4 Micro ATX LGA1700 Motherboard  (£134.96 @ More Computers)
Memory: Corsair Vengeance LPX 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory  (£112.38 @ Aria PC)
Storage: Samsung 970 EVO Plus 2 TB M.2-2280 NVME Solid State Drive  (£178.49 @ Amazon UK)
Video Card: MSI GeForce RTX 3070 Ti 8 GB VENTUS 3X OC Video Card  (£729.99 @ Technextday)
Case: Corsair 4000D Airflow ATX Mid Tower Case  (£79.86 @ CCL Computers)
Power Supply: Corsair RMx (2021) 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (£112.99 @ AWD-IT)
Case Fan: ARCTIC P12 56.3 CFM 120 mm Fan  (£4.99 @ Amazon UK)
Total: £1709.39
Generated by PCPartPicker 2022-04-01 17:38 BST+0100
Power Supply: Corsair RMx (2018) 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (£134.99 @ Amazon UK)
Total: £1731.39
Generated by PCPartPicker 2022-04-01 17:37 BST+0100
Thanks bro do you know what fps this would give me and the quality of the video and what the difference between an i7 than an I9?
you will net around 50-70 fps on 1440p Max settings in most games but in 1080p Max settings you are looking at around 150 fps. also the difference between the i9 and i7 is the core count and e cores
