One thing I've noticed is that when I use an HDD in some laptops, normally when your CPU reaches a certain temperature, it will shut off and stay off until it reaches 55 or 60 degrees Celsius. However, when I use an SSD in some of the laptops, the CPU fan never actually shuts off; it stays on but you can barely hear or feel it, whereas when an HDD is installed, the fan actually shuts off. Why does it do that?
https://linustechtips.com/topic/1421691-laptop-cpu-fan/
Probably background process' lined up waiting for disk space/activity to free up, did you also notice the cpu usage slightly higher on the HDD??
I thought it was just me but when I first got an SSD in the early 2010s I could've sworn my CPU usage went down.
My rig:
CPU: Ryzen 7 5800x
MB: Gigabyte B450 I Aorus Pro WiFi
RAM: Kingston Fury Beast RGB 32GB (2x16GB) 3600mhz CL16 (1-to-1 Infinity Fabric enabled)
GPU: Gigabyte RTX 2080 Super
*bought for $200 CAD off a friend who needed an RTX 3080, price was my reward.
CASE: InWinn A1 Plus in White with included 600w gold sfx PSU and included custom length cables
DISPLAY: 3x 20" AOC 1080p 60hz 4ms ,  32" RCA 1080p/60hz TV mounted above, all on a single arm.
Storage: C : 1TB WD Blue NVMe      D : 2TB Barracuda      E: 240GB Kingston V300 (scratch drive)
NAS: 240GB Kingston A400 + 6x 10+ year old 700GB Barracuda drives in my old FX8350+8GB DDR3 system
Logitech G15 1st Gen + Logitech G602 Wireless
Steam Controller +  Elite Series 2 controller + Logitech G29 Racing Wheel + Wingman Extreme Digital 3D Flight Stick
Sennheiser HD 4.40 Headphones + Pixel Buds 2 + Logitech Z213 2.1 Speakers
My Girlfriends Weeb-Ass Rig:
Razer Blade Pro 17 2020
10th Gen i7 10875H 8c/16t @5.1ghz
17.3" 1080p 300Hz 100% sRGB, factory calibrated, 6mm bezel
RTX 2070 Max-Q 8GB
512GB generic NVMe
16GB (2x8GB) DDR4 3200Mhz
Wireless-AX201 (802.11a/b/g/n/ac/ax), Bluetooth® 5.1, 2.5Gbit Ethernet
70.5 Whr Battery
Razer Huntsman Quartz, Razer Balistic Quartz, Razer Kraken Quartz Kitty Heaphones
*deep breath*
Razer Raptor 27" monitor, IT'S BEAUTIFUL.
https://linustechtips.com/topic/1421691-laptop-cpu-fan/#findComment-15329874
He's saying the opposite tho. That's a general problem in this forum, people don't read the questions properly and I've made that mistake as well. Also careful with that OC in your sig. You might degrade the CPU.
To the OP, you probably kept HDD cleaner to make it faster since it's a very slow device, and that might have resulted in lower CPU usage. Or even simpler, your power options in HDD are different. It has to be software related.
https://linustechtips.com/topic/1421691-laptop-cpu-fan/#findComment-15329903
Could be I have checked the CPU usage but it is low like 10 to 2% which doesn't make that much difference.
https://linustechtips.com/topic/1421691-laptop-cpu-fan/#findComment-15329961
A HDD cleaner not that I'm aware of but it could maybe be the power options the power mode is on "Balanced" on Windows 10
https://linustechtips.com/topic/1421691-laptop-cpu-fan/#findComment-15329962
