so can i use the Bitspower Water Tank Z-Multi 250 Inline Reservoir horizontally not vertically?
yes, but for fully functionality, removing all of the air from the reservoir would help
coolant flow a lot. and note that the exit of the coolant needs to be the lowest point
of the res if possible. if not that reduces some of the "functionality" as the intended
use is to capture air from the system.
ill keep that in mind/ thanks
if you are reading this you are wasting valuable time and should maybe rethink your life choices.
