Budget (including currency): Under $4200 USD
Country: Sweden
Games, programs or workloads that it will be used for: Gaming and streaming
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): I am looking at this parts list https://se.pcpartpicker.com/list/ctm278 and I am looking at a 2nd 21 inch monitor for vertical use. I am upgrading form a Lenovo prebuilt, the Lenovo Legion T530-28ICB. It has a I5 9400f, 1660ti, 1 dim of 16gb 2666mhz, 520GB of Samsung m.2, and a 2tb hard drive. I am gaming at 1440p at 144hz. Titles like CoD WarZone I can only play at 1080p on 50 - 60 fps with nothing open in the background and on the lowest setting. I will also be reusing my storage. Is there anything I should change or add to this list? It looks something similar to the image.
https://linustechtips.com/topic/1420062-pc-upgrade-help/
add another ram perhaps so it works dual channel. although it will not significant. 10%~. 1440 is really heavy most of ppl either lpwer setting or upgrade to higher end card
  Spec: Macbook Air 2017
ProcessorPU: ii5 (I5-5350U |
| RAM: 8GB LPDDR3 |
| Storage: 128GB SSD
 | GPU: Intel HD 6000 |
| Audio: JBL 450BT Wireless Headset |
https://linustechtips.com/topic/1420062-pc-upgrade-help/#findComment-15318855
That is what I am using now and the list is the upgrade
https://linustechtips.com/topic/1420062-pc-upgrade-help/#findComment-15319137
