This is extremely dangerous. If it's not grounded, it could electrocute you, because it can and will use YOU as the ground. Electricity follows the path of least resistance.
Edited by An0maly_76
Revised, more info
I don't badmouth others' input, I'd appreciate others not badmouthing mine. *** More below ***
MODERATE TO SEVERE AUTISTIC, COMPLICATED WITH COVID FOG
Due to the above, I've likely revised posts <30 min old, and do not think as you do.
THINK BEFORE YOU REPLY!
https://linustechtips.com/topic/1419884-static-problems/#findComment-15317291
2 minutes ago, Kgords said:
But is it dangerous for the computer tho?
Potentially, yes, but I'd be more concerned about an ungrounded electrical system's ability to kill you.
https://linustechtips.com/topic/1419884-static-problems/#findComment-15317349
3 hours ago, Kgords said:
properly
What do you mean?
You know if you build your system place it on a glas table it is not grounded as well.
And I wouldn't worry about it
Please elaborate a little bit more
Gigabyte X570 Aorus Elite,  Ryzen 9 3900x, Dark Rock Pro 4, 16 GB Crucial Ballistix  RGB 3600 MHz CL16 RAM, RTX 3080 TI FE Watercooled, 6 Case Fans,  Fractal Design Meshify S2
You are awesome, stay safe and healthy.
https://linustechtips.com/topic/1419884-static-problems/#findComment-15317417
1 hour ago, Kgords said:
It shocks me when i touch like some metal parts
O.o
That is very very alarming
What kind of floor do you have wooden, carpet? Fluffy carpet?
https://linustechtips.com/topic/1419884-static-problems/#findComment-15317508
