Drivers/Windows problems.
Go to solution Solved by Robchil,
partition magic used to have a bootloader you could easily swap between installs.. but that's ages ago i used that.. .. linux also have bootloader that works. but the other C drive will be invisible i think.. a bit depending on how you set it up... but search for free bootloader dualboot, or multiboot. you should find something you can use.
I have a really big problem.
I can't find drivers for 3060 ti for windows 8.1 / 8.
And if I try to install windows 7 I can't install it because my keyboard and mouse doesn t work when i start the installer.
I really need help with this guys ... windows 10 it s working fine but i need win7/8 for one old program.
https://linustechtips.com/topic/1419881-driverswindows-problems/
Why not run W10 and get windows 7 on a VM like virtual box?
Since you only need it for one program, long as it works it seems like a good compromise
Cause after that i need to use files from ssd (i want to dual boot win 7/8 and 10), and from virtual box it s impossible. So i need to install win 7/8 .... and i can t it s impossible ... it s day 3 of trying and still nothing..
you can still mount disks or directories so you can access local files inside the VM...
