Hi I just bought a ASUS 3060 ti ko oc 8gb
https://www.newegg.ca/asus-geforce-rtx-3060-ti-ko-rtx3060ti-o8g-v2-gaming/p/N82E16814126526?Description=asus 3060 ko&cm_re=asus_3060 ko-_-14-126-526-_-Product
is there a water block out there that anyone has used or know of for this card
https://linustechtips.com/topic/1419652-water-block-for-my-gpu/
Supposedly (according to a couple forums I found) it's very similar to the TUF PCB which works with this block. Someone also used a 3070 KO with that block and it worked, and since the 3070 KO and 3060 Ti KO are very similar cards I'd assume it works as well. Just buy it on Amazon so you can return it if it doesn't fit.
https://www.bykski.us/products/bykski-full-coverage-gpu-water-block-and-backplate-for-asus-dual-rtx-3070-3060ti-n-as3070dual-x-v2
That said, are you sure you want to water cool that card? The $200 you'd spend on that block would be better spent selling the card on eBay and buying a 3070 or 3070 Ti instead, not including the rest of the cost of the loop.
https://linustechtips.com/topic/1419652-water-block-for-my-gpu/#findComment-15315746
i have a custom loop already and I've been waiting to get my new gpu so that i could finally finish the loop with a the gpu block and in my area i cant find a 3070 for cheaper than 1400 i don't have that i got lucky and got a drop on the 3060 ti and only paid 759 and i put it up for sale for shits and giggles and the most i was offered was 1100 for it
https://linustechtips.com/topic/1419652-water-block-for-my-gpu/#findComment-15315749
