Hi guys I am new here,
So I am looking for software that can separate the audio from different programs when recording. In addition I would prefer that it be free, however I understand that sometimes the only option is to pay.
Anyway so I use PlayClaw to record video and it has the ability to save different audio sources into different tracks so that they can be edited by themselves as oppose at the same time. So I have one for my mic and one for computer sounds, however sometimes I will be doing something where someone is talking to me on Skype and it would be great to have Skype sound as it's own channel. So then I could lower the computer sounds and yet keep their volume correct, or mute something they are saying and keep the computer sounds there.
Anyways so I found this however I have found it costs money, only a little but I thought I may as well ask on here just incase there was something out there that can do it better or perhaps for free.
If anything doesn't make sense, just let me know and I'll reword it ;)
Well thanks in advance!
~_Stads_
https://linustechtips.com/topic/141739-separate-audio-from-programs-when-recording/
You can mute Skype in volume mixer in the volume icon in the taskbar.
Intel Core i5 3570K@4.5GHz | ASRock Z77 Extreme4 | 2*TEAM 8GB DDR3-1600@CL9-9-9-27 | Inno3D GTX 660 HerculeZ 2000s@1200MHz Core 6600MHz Memory | Seagate Barracuda 2TB | Antec Kühler H2O 620 | Antec HCG-620 | CoolerMaster Elite 371
Acer Iconia W700: Intel Core i5 3337U | 4GB DDR3 | 120GB SSD | 11.6" 1080p Display
Please make your text black!
Okay, sorry about the weird colour. Fixed it ;)
The issue with that is, I still want to record the audio from Skype or team speak or whatever it is, I just want to have it separate from computer or game sounds. To my understanding muting Skype in the volume mixer will cause it to not be recorded at all.
There is free option for VAC called VB Audio Virtual Cable. Downside of being free is that you can only add one virtual channel. I've used it to filter TS3 from my speaker output. Their site has other interesting audio projects but I don't understand that much of them.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
Black text on the dark theme doesn't work very well.
Desktop: Intel Core i7-6700K, ASUS Z170-A, ASUS STRIX GTX 1080 Ti, 16GB DDR4 RAM, 512 GB Samsund 840 Pro, Seasonic X series 650W PSU, Fractal Design Define R4, 2x5TB HDD
Hypervisor 1: Intel Xeon E5-2630L, ASRock EPC612D8, 16GB DDR4 ECC RAM, Intel RT3WB080 8-port RAID controller plus expansion card, Norco RPC-4020 case, 20x2TB WD Red HDD
Other spare hypervisors: Dell Poweredge 2950, HP Proliant DL380 G5
Laptops: ThinkPads, lots of ThinkPads
That's why users shouldn't make text in any color. If its just default it will be black in normal and white-ish in dark.
Run skype/vent/teamspeak/etc. on a different system (I have done this with my laptop before) and record them separately and sync them up in editing. Another possibility is that you run skype in a VM(Virtual Machine) and record in there, but I not 100% sure that would work as I have never tested it.
This is a little bit of work but it might be worth a try to some.
I had a bit of look into that, but I couldn't find a way of splitting audio from different programs. Only a way to redirect the entire computer sound which includes everything...
Can you explain how exactly I can split different audio, if it does in fact have the functionality?
That is a good idea, and I could possibly do it as a last option however I'd prefer not to have to do that due to in-game push to talk and whatnot. But that is a good idea and if I cannot find any other solution I will result to doing this ;)
Your audio source needs option to select output. Like my Teamspeak is set to output into VB. So if I'd had program which could record several audio sources I'd select VB for Teamspeak audio. Ofc I use it to filter TS out of stream audio.
