Punch Keystone Jack issues
Solved by OddOod,
18 hours ago, Ertman said:other keystone options
One bad jack in a pack is maybe possible, multiples though? Unlikely. And I assume the jack appears fine when you replace it.
18 hours ago, Ertman said:rerunning the cable might be worthwhile
It might solve the problem and as long as it's not a PITA, can't hurt. On the other hand if it's gonna involve drywall and paint, then don't bother, the marginal effort of just replacing the jack every couple years means that as long as you don't run out of slack you will likely age out of the house before the problem becomes dire
