Devices that can use the 5GHz band will, and the ones that can't just use the 2.4GHz band. You can't change the channel, btw you must have a dual band router, thus the 5GHz band becomes available. Though if al of the devices you have you can make the router use only the 5GHz band, check the manual with your devices to see if they support it. I'm also pretty sure the 5GHz band has a smaller range, though I'm not entirely certain.
CPU: Intel i7 8700K | CPU Cooler: be quiet! Dark Rock Pro 3 | RAM: Kingston HyperX 2x8GB | Motherboard: Asus ROG Z370-E | GPU: MSI GTX 970 | HDD: Seagate Barracuda 1TB & 2TB | SSD: Samsung 840 EVO 250GB & 970 EVO M.2 500GB | Case: Phanteks Enthoo Evolv X | PSU: Silverstone Platinum Strider 1100W | Monitor: AOC i2367Fh | Headphones: ATH-M40X | Mic: Antlion ModMic 4 | Keyboard: Corsair K70 RGB w/ MX Browns | Mouse: Logitech G502 HERO
Make sure you quote or mention the person you're replying to in your comment. Also remember to follow your thread when creating it to get a notification every time someone replies.
Be nice and have fun. Cheers!
https://linustechtips.com/topic/141695-help-wifi-channels/#findComment-1891684
It won't change the internet speed if your getting the rated speed that you pay for from your ISP but prevents packet loss if your router is operating on crowded channel equaling better speed to the router but if you have good router and it's set to auto them your already on the optimal channel.
That's the frequency not channel.
Mein Führer... I CAN WALK !!
https://linustechtips.com/topic/141695-help-wifi-channels/#findComment-1891690
2.4ghz and 5ghz aren't channels they're bands. Channels can be changed on almost every router from within wifi settings.
http://i.imgur.com/WIYTgFr.jpg
https://linustechtips.com/topic/141695-help-wifi-channels/#findComment-1891701
Ah *facepalm*, sorry I got confused lol.
https://linustechtips.com/topic/141695-help-wifi-channels/#findComment-1891715
