Budget (including currency): 2500~3000 USD; I have a decent paying job right now while I am in college and I’ve really been wanting this
Country: U.S.A.
Games, programs or workloads that it will be used for: Minecraft, FPS (R6, COD), Civ 6, Super Auto Pets (lol); schoolwork, web surfing
PCPartPicker Part List: https://pcpartpicker.com/list/nVfQVw
CPU: AMD Ryzen 7 5800X 3.8 GHz 8-Core Processor
CPU Cooler: Lian Li GALAHAD AIO 360 RGB UNI FAN SL120 EDITION 58.54 CFM Liquid CPU Cooler
Motherboard: Asus ROG STRIX B550-A GAMING ATX AM4 Motherboard
Memory: G.Skill Trident Z Neo 32 GB (4 x 8 GB) DDR4-3600 CL18 Memory
Storage: Samsung 970 Evo Plus 1 TB M.2-2280 NVME Solid State Drive
Video Card: Asus GeForce RTX 3070 8 GB STRIX OC Video Card
Case: Lian Li PC-O11 Dynamic ATX Full Tower Case
Power Supply: Corsair RMx (2021) 750 W 80+ Gold Certified Fully Modular ATX Power Supply
Operating System: Microsoft Windows 10 Home OEM 64-bit
Case Fan: Lian Li UNI SL120 58.54 CFM 120 mm Fans 3-Pack
Monitor: *Acer VG271U Pbmiipx 27.0" 2560x1440 144 Hz Monitor
Total: $2510.66
No peripherals other than the monitor are needed; I have already bought a mouse and keyboard. However, I am having trouble deciding which 1440p 144hz monitor specifically to buy. This will be my first build. I plan on buying a GPU as soon as I can get one at MSRP, I am either looking for a 3070 or 3080, preferably the white Rog Strix OC; then, I am going to buy the rest of the components. I want to play at 1440p 144hz. I really like the look of a white build, so that is what I was going for here. I wanted to reach out to see if this is a well balanced build, and to ask about two issues. Firstly, I know that there is no USB 3.2 Gen 2 header on my motherboard, which means the USB 3.2 Gen 2 on the front panel of the case wouldn’t work. I don’t know how much I would even use that, but I know of another white motherboard a bit above my price point, the Asus Prime X-570 Pro. Would this be better for my build, or am I better sticking with the current one. Secondly, for my storage, I know my current SSD is PCIE 3, and I’m not sure if I should spend a bit more to get PCIE 4.
https://linustechtips.com/topic/1415419-first-pc-building-experience/
I don't see any USB 3.2 Gen 2 (although I'm not confident that USB3.0 and 3.1 are better suited)
Oh, you probably mean USB-C...
You could always buy a cheap pcie card with an USB-C header if you ever need it
If you don't quote us, we won't know you answered
