23 hours ago, brob said:
It's better to save up for a new system unless there is a particular issue with the existing system.
If you have to spend on the system consider things like a large SSD (1TB) or a new monitor.
what monitor would my system be able to handle in terms of resolution and hertz?
https://linustechtips.com/topic/1415397-need-help/#findComment-15288341
In what game?
In anything modern AAA or demanding, 1080p or less, 60fps tops, graphical settings minimum.
Are you sure the GPU isn't an Nvidia GTX 550 ti? Because that would be way worse.
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
https://linustechtips.com/topic/1415397-need-help/#findComment-15288346
19 minutes ago, Middcore said:
In what game?
Its an asus rx 550 4gb
Im more of an indie gamer or roguelike. Hades , hollow knight, dark souls 3, league, valorant, etc.
Would it help if I just got a new graphics card?
https://linustechtips.com/topic/1415397-need-help/#findComment-15288365
RX 550 is basically at the minimum spec for Dark Souls 3.
https://linustechtips.com/topic/1415397-need-help/#findComment-15288371
