Cpu usage high until i open task manager
My Acer laptop's fan has been running very loudly these past few weeks. When it gets too unbearable, I open Task Manager, only to find that my cpu usage lowers dramatically from 100% going as low to 13%.
I checked that the usage is high through a third party app.when i open task manager it goes low
https://linustechtips.com/topic/1415204-cpu-usage-problem/
Not enough info for a valid assumption. I can only guess; spyware that tasks your CPU or the laptop needs cleaning/repasting.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
https://linustechtips.com/topic/1415204-cpu-usage-problem/#findComment-15284641
Windows likes to hit the CPU hard when you aren't using your device. I keep noticing the fan on my laptop wramp up high when I'm away from the laptop and only spotify is playing music but as soon as I open Task manager to check what is loading it so hard, nothing is there and the fan is able to wramp down again. Since opening Task manager is you using the computer from the perspective of Windows it cancels whatever background task it was running for you to have full CPU power again
https://linustechtips.com/topic/1415204-cpu-usage-problem/#findComment-15284660
52 minutes ago, kyomamad said:
Found this trojan. Windows defender continuously shows threats even after removing.
wacatac.b ml
Installed Malwarebytes and deleted some trojans found Hope this solves it.
If it keeps happening, just keep Task Manager open and leave your computer idle and look at what task consumes the most CPU power by sorting the tasks by CPU power
https://linustechtips.com/topic/1415204-cpu-usage-problem/#findComment-15284694
