Connecting display through USB
Ok so there are a few things at play here.
First, he requirement for DP is for using G-Sync on Freesync panels that are G-Sync compatible.
USB Type C, which that laptop does not seem to have, in many cases supports something called DisplayPort Alt Mode over USB Type C. In this instance, a true DP signal is passed through the USB Type C port and to a DP display. In that instance, assuming the specific implementation of the USB Type C port connects the DP signal to the dGPU, that "might" work.
All moot unless I'm wrong and you DO have a Type C connector.
Now, your normal USB3 Type A ports are not connected to your GPU (unless there is some weird specific to that laptop trickery going on, wouldn't put it past them) so there is no way to get a DP signnal from your GPU directly to your monitor.
Now, there are adapters that are essentially extremely low powered 2D GPU's that take your USB3 port and give you a basic video output, however these are in no way connected to your GPU, they show up as their own video output device. Most are based around the DisplayLink technology and I've used quite a few from Plugable. You cannot game on these. https://plugable.com/collections/usb-graphics-adapters
I don't think you're going to get VRR with that display.
