HI All,
since my 2014 build died recently I'm planning my new 'Litt'' Build (there will be RGB in this MF)
What ya'll saying about this build?
https://uk.pcpartpicker.com/list/WLLNGL
I'm considering a white version of the Corsair 4000 D Airflow and mostly white parts. the MOBO isn't available in white, still undecided if it'll look good or horrible wiith a black board and the display that comes with the H100i ELITE LCD.
John
https://linustechtips.com/topic/1412068-litt-build-2022/
Motherboard being more than the cpu is pretty awful. Recommend these changes below, and going with high performing DDR4 RAM. DDR5 RAM is way overpriced right now, as well. You can get double the storage as well. I would recommend a new psu as well. Keep your old one as a backup, if you like. 🙂
Went for the white components, like you originally wanted as well. Recommend mounting the 360 AIO at the front of the case (intake), and putting the rest of the fans at the top and back of the case (exhaust).
https://uk.pcpartpicker.com/list/3F93C6
CPU: Intel Core i7-12700K 3.6 GHz 12-Core Processor  (£345.29 @ Amazon UK)
CPU Cooler: Corsair iCUE H150i ELITE LCD 58.1 CFM Liquid CPU Cooler  (£246.00 @ Infinite Computing)
Motherboard: Asus ROG STRIX Z690-A GAMING WIFI D4 ATX LGA1700 Motherboard  (£297.99 @ AWD-IT)
Memory: G.Skill Trident Z Neo 32 GB (2 x 16 GB) DDR4-3600 CL16 Memory  (£195.38 @ Newegg UK)
Storage: Samsung 970 EVO Plus 2 TB M.2-2280 NVME Solid State Drive  (£179.99 @ Amazon UK)
Video Card: EVGA GeForce GTX 1080 Ti 11 GB Gaming iCX Video Card  (Purchased For £0.00)
Case: Corsair 4000D Airflow ATX Mid Tower Case  (£79.00 @ Computer Orbit)
Power Supply: Corsair HX Platinum 1000 W 80+ Platinum Certified Fully Modular ATX Power Supply  (£154.99 @ Currys PC World Business)
Operating System: Microsoft Windows 10 Pro French CDN - DVD 64-bit
Case Fan: Corsair LL120 63 CFM 120 mm Fans 3-Pack  (£64.98 @ Amazon UK)
Monitor: Asus ROG SWIFT PG348Q 34.0" 3440x1440 100 Hz Monitor  (Purchased For £0.00)
Keyboard: Logitech diNovo Edge Bluetooth Wireless Mini Keyboard  (Purchased For £0.00)
Mouse: Razer Ouroboros Wireless Laser Mouse  (Purchased For £0.00)
£1563.62
Am I still to create the perfect system?! ~ Clu
Keep your expectations low, boy, and you will never be disappointed. ~ Kratos
https://linustechtips.com/topic/1412068-litt-build-2022/#findComment-15264003
