Cpu and Motherboard swap help
Solved by SimplyChunk,
Just swap it all over and boot it up. Give windows 10, 10 minutes at the start and you won't even need to reinstall it. once you're in windows open up control panel, open adminastrative tools, open computer management, open storage open disk manahement. find your drive partitions and right click them to 'mark partition as active' You should be good from there
Featured Topics
PDifolco ·
Posted in Graphics Cards1 -
HARDWELL9191 ·
Posted in CPUs, Motherboards, and Memory2 -
ChrisLoudon ·
Posted in Laptops and Pre-Built Systems1 -
midix ·
Posted in CPUs, Motherboards, and Memory1 -
2
Hotblood ·
6
11
play_circle_filled
Latest From ShortCircuit:
Lian-Li, do this on all of your cases! - Lian-Li O11D x Lamborghini
