Case for B360
Go to solution Solved by --SID--,
1 hour ago, BurstHearts said:
Format: mATX
Jonsbo C2 is a 12L mATX case that fits an ATX PSU.
Pcyes Electro V2 550w
Local brand? You're in Brasil?
Hello there!
Does anyone know the smallest PC case that will fit a B360 motherboard?
So i am adding a second PC to my bedroom. And because of the space i want to reduce the size of my old one (that i use for work). But i am not feeling like spending on ITX hardware and neither buy a laptop.
I don't mind getting a new PSU, but prefer not to. Just don't want to spend on a new MB as they can be quite expensive and i am spending a lot on my new PC already.
https://linustechtips.com/topic/1409590-case-for-b360/
Yup PCYes is a local brand. I am in Brasil.
And that case looks perfect. We can find Jonsbo here, so it will be alright. Thank you for finding it
https://linustechtips.com/topic/1409590-case-for-b360/#findComment-15245958
FYI: motherboard sizes don't vary by chipset. So "a case that fits a B360 motherboard" is meaningless. Consumer B360 boards came in the same ATX, micro-ATX, and mini-ITX form factors as every other chipset. (I omit E-ATX because while "E-ATX" B360 boards might have existed, there is no actual standard for E-ATX.
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
https://linustechtips.com/topic/1409590-case-for-b360/#findComment-15245998
