For month's I have problem that my PC keep random freezing with buzzing sounds from speaker but it's super rare that I get BSO most time it just take 10-15sec. Looks like finally I understand what course that problem it keep freezing only while I watching video in browsers any idea how finally fix that problem ? Change browsers not help and I use latest browsers version and Nvdia driver. In stress test for GPU or CPU can run fine hours without any problem but while I start watch video in browser it randomly keep freezing sometime I watch 2-3+ hour without any problem but sometime it freeze in first few min.
https://linustechtips.com/topic/1409477-pc-keep-freezing/
12 minutes ago, stage said:
Please post your full system specs and OS and version so we don't shoot in the dark.
CPU I7 7700
RAM 2 x 8 Gb DDR4 2400 Mhz
GPU RTX 2080
PSU Seasonic 850 PX Platinum
Samsung SSD 960 Evo 500 gb + Samsung SSD 850 Evo 500 Gb
Motherboard Gigabyte Z270
OS Windows 11 and I know officially my PC not in support list for W11 but I can tell that is not OS problem due that random freeze happen even than I used W10.
And as I say that random freeze happen only while watching videos in browsers it never happened in any other circumvent.
https://linustechtips.com/topic/1409477-pc-keep-freezing/#findComment-15245171
Can you try disabling hardware acceleration and see if that changes anything.
https://support.mozilla.org/en-US/kb/hardware-acceleration-and-windowblinds-crash
Not sure what other browsers you use, but there should be a way for them too, so please google your own solution.
https://linustechtips.com/topic/1409477-pc-keep-freezing/#findComment-15245184
I will try do that but I use this PC about 3 year and that problem start happen only like half year ago.
https://linustechtips.com/topic/1409477-pc-keep-freezing/#findComment-15245187
6 hours ago, Winterlight said:
CPU I7 7700
GPU RTX 2080
Does event viewer-> system logs show any error or critical logs around that time?
I would first make sure your drive is healthy (even if you recently updated to w11)
in command prompt: chkdsk /f /r (you will need to reboot and wait)
After reboot in cmd: sfc /scannow
Then download DDU and wipe out old GPU drivers, and reinstall
Update any drivers you can after that
Also you can update your UEFI BIOS
https://linustechtips.com/topic/1409477-pc-keep-freezing/#findComment-15245573
No critical error I get just some warning. Always been 2 same warring at that freeze time "Display driver nvlddmkm stopped responding and has successfully recovered." and "The application-specific permission settings do not grant Local Activation permission for the COM Server application with CLSID"
https://linustechtips.com/topic/1409477-pc-keep-freezing/#findComment-15247272
Display driver issue there it is, so either your GPU is overheating, corrupted driver or faulty HW most likely.
Steps above are still good to try
https://linustechtips.com/topic/1409477-pc-keep-freezing/#findComment-15247353
No it not overheat done stress and it never hit temp limit. I have latest driver and done clean driver install. What is HW? Btw every this freeze I hear buzzing sound from speaker.
https://linustechtips.com/topic/1409477-pc-keep-freezing/#findComment-15247510
Sorry, hw= hardware.
Wheb you say clean install did you specifically do DDU?
Downloading a driver and selecting clean install does not mean it removed all old drivers sadly.
The sound buzzing is likely the sound not being sent properly/de synced when the driver crashes.
https://linustechtips.com/topic/1409477-pc-keep-freezing/#findComment-15247691
