I was making a script in Linux.
Which first asks the question of your name
then as in cmd we write x this corresponds to x.
This part works. But the second part doesn't work.
Then it asks how old you are and it turns off.
It should be so that we enter how old we are and if we are 18, we invite you to answer, and if not, buy it.
What does $ a and -gt mean?
-gt probably means that when we are 18, we invite you to answer and buy if less responds.
I'm still sending photos.
https://linustechtips.com/topic/1405837-is-this-script-with-variable-done-right/
You asked for age but did not capture the input
Add
read a
after
echo "ile masz lat"
This line
if (test $a -gt 18)
is checking to see if the value ($a) is greater than (-gt) 18
Test is a program that compares two values. Run man test for documentation
You dont need to take screenshots of your code. Press the <> button when posting code.
